Question about Kenmore Elite 45986 Front Load Washer
Top load will not drain
Kenmore elite-top load
    Sergeant:
  • 175 Answers
Hi..the reason to this problem may be the clogging
or the pump could be faulty.
check this out..
thank u..
kindly rate my response..
Posted on Jul 14, 2009
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
Jun 13, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite washer does not drain; 2002 Top load.. It does spin, but it is not draining the water
Check the drain hoses and pump for blockage. Look carefully if not obvious, I had one with a quarter in the drain hose and it acted like a flapper and gave intermittent symptoms.
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Drain pump for Kenmore Elite top loading washing mechine
This will not be in the owner's manual.
If you search inside the cavity of your washer, however, you will find the service manual taped to the wall in a plastic bag.
Aug 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
74 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
