Question about Jenn-Air JXT5830AD Kitchen Hood
Switch/Controller Problem Odd problem and with the price of the control board being $235 and the switch only $58 I need to find out which one is bad: Each switch for the fan and light work fine through all settings (fan; hight, med, low and light bright and dim) IF SWITCHED ON ALONE but if I have the light on and try to turn on the fan (which defaults to MED/pos2) the light will remain on but the fan will make a slight noise then be silent. If with the light still on, then switch the fan to LOW/pos1 or HIGH/pos3 the fan will turn on and the light will stay on and it works fine. If I turn on the FAN first then the light, no matter what teh fan setting, will only do on at the Dim0nightlight setting! I was told that not only does the unit have the centrally mounted Electronic Control Board but the switch assembly also has a circuit board in it so I am unsure how to proceed. I cannot find any troubleshooting guide/test parameters for this unit anywhere and Whirlpool/Jenn-Air were no help. As a side note, the parts guy says that, yes, the front mounted switch assembly is only $58 BUT that the "ribbon Connecttor" can NOT be reused then tells me that the short piece of cheap ribbon is over $300! I gathered after he checked a bit that that price gets you the ENTIRE wiring harness???? WHy can I NOT reuse the ribbon connector? on computer obards one can trim off the penetrated section and reuse it. ANY help will be GREATLY appreciated!!!!! Doug
4 Suggested Answers
heavyt15
  • 91 Answers
SOURCE: Jenn Air JXT8136ADS Hood...A bulb burned out and now can't turn
On going problem...switch..replace
Posted on Nov 04, 2009
heavyt15
  • 91 Answers
SOURCE: The lights dont turn off anymore
On line....sound control board to me...
blueextc3221
  • 15935 Answers
SOURCE: Jenn-Air Hood - Turns on high by itself and will not turn off.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Power is coming in to controller, chnged fuse , no lights on
check voltage to switch if ok check relay if voltage check to light possible bad bulb
Mar 15, 2014 | Goldline Solar Auto Controller GL-235
Tip
ERROR codes Canon 6045
Canon 6045 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace, same possibilities as E000. E003 Fuser temperature drops. Same as E000. E004 Fuser problem: AC driver, SSR bad, wire shorted. E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this. E006 Fuser feed connector. E010 Drive problem. Main motor, gears, etc. E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times. E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller. E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller. E030 Total counter. E031 Option counter or total counter. E050 Holding tray (duplex) home position sensor motor or board. E051 Holding tray (duplex) home sensor motor or board. E202 Panel locked up, but might be no code, scan motor problem. E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem. E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor. E402 RDF belt motor or pulse sensor. E403 RDF feed motor or pulse sensor. E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motorE522 Sorter push bar motor E523 Sorter reference wall motor E524 Sorter multi-guide motor E525 Sorter bin paper sensor automatic adjustment problem E526 Sorter bin paper sensor automatic adjustment problem E530 Sorter guide bar motor E531 Sorter stapler motor E532 Stapler motor E533 Stapler inside paper sensor E540 Sorter bin shift motor E550 Sorter power supply E710 DC controller E711 DC controller E712 Document feeder IC failure E713 DC controller, sorter E800 Auto power off circuit problem. Main switch or DC controller. E802 Auto power off circuit problem. Main switch or DC controller.
on Jan 19, 2010 | Office Equipment & Supplies
No lights on Goldline GL-237
if voltage to unit check switch if ok check voltage from transformer if ok bad display
Mar 13, 2013 | Goldline Solar Auto Controller GL-235
When turned on right hand display comes up with 51 then flashes with the number 68. Dead man button works but not any of the controls. Alex
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
Jul 14, 2011 | Avanti Fitness AT380 Treadmill
I have Lionel Fastrack 048 switch. I extended the controller wire and all of my slices are perfect. The switch operates but the light in the controller does not operate - neither red or green. I checked...
You will need to check continuity of the yellow RSC wire from inside the controller to where it enters the switch connection block. Neither light will work if this wire is broken.
2nd: Lionel quality control is so poor that if that is not the problem, remove the plate from the bottom and make sure the five plugs are firmly in place on the electronic board. Since both green and red do not work it is most likely not the micro switchs but an issue with the circuit board.
Jan 01, 2011 | Lionel Fastrack O36 Manual Right Hand...
We've a Ricoh MP3500 that is displaying an error code SC672 and directs us to switch the main power and switch back on. When switched back on, we have the same error code. Advice?
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Jul 16, 2010 | Ricoh Aficio AP3800C Laser Printer
How do i take a shure ur2 apart to replace the switch?
It is very easy to damage the element in these, and it is expensive to replace.
Look for guts to come out the bottom end. I can't imagine why you would be changing the circuit board, How do you know there is a problem with the circuit board?
Some of these have a label over the switch that has screws underneath. When replacing the element they give you new labels as one destroys them when you remove the label to get at the screws underneath.
Mar 28, 2010 | Shure U2 / 58 with SM-58 Professional...
Commercial generator 20kv not working properly
Troubleshoot like this:
1 - With the generator control in Auto, jumper from terminal 3 to 4 on the control board. Generator should start without transfer switch doing anything. If it won't you have a bad controller board.
2 - If the Generator started, remove the jumper - controller is OK. Next go to the 1st transfer switch and find the remote start terminals. These will be the same wires that were connected to controller terminals 3 and 4 at the generator. Use your jumper wire to connect them and see if the generator starts, if not there is something wrong between the switch and the generator, probably a broken wire.
3 - Don't forget to check the other switch, the remote start terminals of the switches connect in parallel across controller terminals 3 and 4 so that either switch can start the generator.
4 - Each switch should have some sort of a test button/switch, power down as much of the building as you can, then run the test function of each switch one at a time. Don't stand directly in front of the switch while you do this.
Nov 20, 2008 | Electrical Supplies
Jenn-Air JXT5830AD Kitchen Hood Logo
53 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
