Question about Kodak EasyShare V570 Digital Camera
Vertical lines on screen. Can't see picture at
Vertical lines on screen. Comes on but can't see picture at all, just white with blue lines.
  • 3 Answers
It sounds like you need a new screen.
Buy one on Ebay for 20 Euro (inclusive of postage)
youtube.com has great videos of how to change a screen.
You will need a tweezers and very small "philips" (cross/plus head) screwdriver.
Make sure the screwdriver has magnets....so that you dont lose some screws....they are tiny.
If you buy a replacement "LCD Screen Display" on Ebay then usually all the tools you need are included. (I just checked).
I also have just replaced my screen....screen was damaged...LCD leaked and lots of vertical lines on a now only WHITE screen.
Camera works fine now.
Check to see if the camera is still working.
Try taking some pictures....and then put the SD-card into your computer to see if the pictures are being taken.
Posted on Oct 20, 2009
  • Qayyum Solangi
    Qayyum Solangi Nov 05, 2013
    there is same with my cam
Why comes white vertical line on my t.v?
Horizontal scan output fault. Check the connections to the deflection yoke from the main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 27, 2015 | LG Televison & Video
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Blue vertical line on LCD screen
Thus meaning what display on the LCD is exactly what "enters" through the lens. Is this a hairline or thick line appearing on the LCD and does the same happen on the photos/pictures when they are downloaded on a PC? If so "something" could have infiltrated into/onto the camera lens....
Jul 16, 2009 | Canon PowerShot SD890 IS Digital Camera
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Kodak EasyShare V570 Digital Camera Logo
373 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
