JVC HD-61z585. No sound. No sound from TV speakers or from audio outputs.
SOURCE: audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Posted on Nov 10, 2007
SOURCE: JVC TH-L1 problems....no sound
I dont think sound is passed thru the HDMI, only video.
Posted on Jan 23, 2008
  • 2336 Answers
SOURCE: Wish to use extension speakers with Bush IDLCD32TV22HD
You will need to get into menu and enable the external speakers. Some older TV may have a switch at the back to turn the external speakers ON.
Posted on Feb 25, 2008
petraman7
  • 1175 Answers
SOURCE: Lost sound on JVC TV
http://www.amazon.com/JVC-AV-48WP30-Widescreen-HDTV-Ready-Rear-Projection/dp/B000066R7X
Cut and paste this link. Amazon's page has a link to the JVC manual. That'll tell you what you need to know
Posted on Feb 28, 2008
  • 6 Answers
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
Can I connect a 3.5mm audio cable from my TV to this JVC RX705V receiver?
So if you're trying to amplify the sound coming out of your TV to an amplifier you need to connect the output on the back of your TV on the receiver to the end audio input on the back of your receiver you might need different types of connections on each end but as long as you take the output on the TV and input it into your receiver your receiver will amplify the sound another way you could do it is to go inside the TV and connect two wires off of each of the two wires of each speaker leaving the internal speakers connected and then plug them in to the audio inputs on your receiver also if you're using one of the audio outputs on TV make sure you go into the menu and tell it you're using external speakers Good Luck Chuck
Mar 28, 2018 | JVC Audio Players & Recorders
I have an old JVC RX6022V audio receiver. We sold the TV that came with it and purchased a brand new TV. The place I bought the tv sold me a digital audio cable. I switched the tv to external speaker...
If your new TV has a digital audio output, your old JVC receiver probably does not have a corresponding digital input. One or the other has to be changed. Look for an EXTERNAL AUDIO output with RCA connectors on the rear of the TV.
Jan 09, 2015 | JVC Audio Players & Recorders
No sound trough the tv speakers on JVC model 52G786
either speakers turned off, or an audio problem which was common on this model----the entire audio circuit is on one board which may still be available.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
You online and did you receive my email concerning no sound on JVC HD 56G886, Part Number: QAS0251-001 . Ed robinson at majorchordstm@sbcglobal.net?
The fault can be confirmed only after a proper audio test is done. The unit must be opened first so that the speakers can be checked for continuity. If this is okay then feed a audio into the audio in and select the video for the auxiliary input. If there is output then the output is good and working and the fault can be with the SIF- sound intermediate frequency section. You will need to inject audio frequency so as confirm the failed section.
Dec 07, 2011 | JVC HD-56G886 56" Rear Projection HDTV
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
Sound on tv went out. model jvc hd-56g886. Checked mute buttons etc
Hello
You just hold your ears very near to the speaker side, and swich on the tv. If you hear a "thumb"; sound, the output circutary of your tv has some trouble; provided picture is Ok. If there is no "thumb sound", the speaker of your tv must be suspected.
Normally output Ic may get damaged. This will happen to most of the telivisions.
Oct 15, 2010 | JVC Televison & Video
Have replaced the bulb in my jvc 61z585 hd-ila rear projection tv. It worked find for two hours. We turned it off for several hours and when we turned it back on we got a picture for ten seconds, then...
Probally the Ballast board have problems,if the safety switch problems,u should not have a picture at all in the first place.Now,the tv turn on?U hearing alot of clicking?Yes,the Ballast board is dead,it not igniting the projection lamp anymore.
Oct 11, 2010 | JVC HD-61Z585 61" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
I just replaced my JVC HD-61z585 lamp but the blue power light and red lamp light just contine to flash on and off. The bulb is definately good.
check the cover you removed to be shure its back on correctly sounds like you have a safty switch open this is usely the case good luck
Feb 04, 2010 | JVC HD-61Z585 61" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
