It fills up..washes..but wont drain or spin out..
I have a frigidaire top loading washing machine..model # fws1339ac1..it fills up..washes..but wont spin or drain out..
  • shashacurbow Jul 14, 2009
    no clicking..you can hear the timer going..which after a couple min's shuts off
  • blueextc3221
    blueextc3221 May 11, 2010
    Do you hear a click before the washer (attempts) to pump and/or spin?
I had the same problem. Checked the pump and it ran fine. Took off the door locking mechanism and put 120 ohms into the wax motor part and it tested fine too. I read about problems with that wax motor so I replaced the complete door switch today for $71.00 and the washer runs perfectly now. If it won't spin or even fully drain I suggest replacing the door switch.
Posted on Jan 09, 2010
  • 52 Answers
Sounds like you have a bad pump.
Posted on Jul 15, 2009
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
My frigidaire front load washer Model #GLTF2940E will not spin out
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Spins but wont drain has a slight burning smell
heatman101
Apr 05, 2011 | Frigidaire FWS833A Top Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
299 people viewed this question
Top Washing Machines Experts
