P0403 - OBD-II Trouble Code - RepairPal
repairpal.com > Encyclopedia > Exhaust & Emissions
Definition of error code P0403 - Exhaust Gas Recirculation Circuit Malfunction. ... TheEGR OBD-II monitor deploys a set of test criteria that are usually run ... Problem, a Plugged or Restricted System, or a Defective Feedback Device ... Nissan ' Volkswagen ' Chrysler ' Lexus ' Mercury ' Cadillac ' Hyundai ' Buick ' Volvo ' AudiMissing: tucson sayes
OBD-II Trouble Code: P0403 Exhaust Gas Recirculation ...
www.obd-codes.com/p0403
Causes. The causes for a P0403 EGR code could be any of the following: ... If the solenoid does operate, you'll have to check current draw on the ground circuit.Missing: huyandai tucson device sayes
Egr P0403 Fault Code Help - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...xg.../102478-egr-p0403-fault-code-help.ht...
SOURCE: 2005 Dodge Caravan P0403 Code
use a mityvac or equivalent handheld vacuum device and while running engine apply vacuum to EGR valve (disconnect line to EGR and plug first)..stumble idicates it is opening and operating one way correctly....computer controls the operation (when and duration)..so left to check is seating (spray carb cleaner around the EGR)......and computer instructing EGR at erroneous times to open (many possible reasons)..good luck and inform me/us of outcome :)
SOURCE: 2005 Huyandai Santa Fe chugs when idle and while
Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
SOURCE: code p0403
The code is EGR cicuit open. I would believe that to mean that if the cicuit is open that the EGR needs to be replaced.
The worst thing, I think, a tech can do is to start throwing parts at a problem, but sometimes that is the only answer if you want to get something repaired without spending hours tracking things down.
Please let me know how it goes.
SOURCE: check engine light on-code says egr valve is bad
the egr system consists of control circuits as well as the egr valve itself. troubleshooting will have to be performed in order to pinpoint the fault. the valve may just need cleaning. there may be damage in the long run since the egr system introduces exhaust gas to the air intake to reduce combustion temperatures.
http://www.aa1car.com/library/egr.htm
With the ignition on and engine off, use a scan tool to activate the EGR solenoid. Listen or feel for a clicking, indicating that the solenoid is operating.
If the solenoid does operate, you'll have to check current draw on the ground circuit. It should be less than one amp. If it is then the problem is intermittent. If it isn't then there is excessive resistance in the circuit and perform the following
1. When it's activated see if you can blow lightly through it. IF you can\'t there may be a blockage causing excessive resistance. Replace EGR solenoid as needed. If there is no blockage, disconnect the EGR solenoid and the PCM connector containing the EGR solenoid control circuit. Using a digital Volt-Ohm meter (DVOM) check resistence between the control circuit and battery ground. It should be infinite. If it isn't, then there is a short to ground on the control circuit. Repair the short to ground and retest as needed.
2. If the solenoid doesn't click as it should, disconnect the EGR solenoid connector and connect a test light between the two wires. Using the scan tool, command the EGR solenoid on. The light should light up. If it does, replace the EGR solenoid. If it does not perform the following: a. Check for 12 Volts on the ignition supply voltage to the solenoid. If it isn't present, inspect the supply circuit for an open, or a short due to chafing or breakage and re-test. b. If it still doesn't operate: then manually ground the EGR solenoid control circuit. The light should light. If it does, repair open in EGR solenoid control circuit and re-test. If it doesn't, replace EGR solenoid.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
