FixYa.com
Tags:
Compaq Cleaning Cartridge 10/20Gb DLT
Failing DAT drive
By Jimmy NY - usenet poster
Is it just me or does everyone have problems with DAT drives failing
after a year of constant use?  We have HP Dat24e drives which last
anywhere from six months to a year.  We are backing up 10-20GB of data
and the backup & verify takes about 8 hours.  This is done on a daily
basis.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
maartenw
maartenw - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
John,
I'm sending you copies attached of previus dialogs about quite the
same thing. You may have your own conclusions, anyway beware of
the stress upon those units, 8 hours a day is too much for any DAT DDS,
by their specs and everybodys practice.
Give a look at the support pages from HP and Sony.
HP drives are rated at only 12% duty cycle!
No need for the verify pass every day as you have "read-after-write"
and it really works.
Have you used them with 10-20GB a day for more than 2 years ?
(You're a survivor, may be there's hope at least!)
Yes, It's in their expected range, no problems.
Beware of moisture, and check the tape storing and handling.
     No temperature changes are allowed right before using the tapes.
     Condensation Kills the drives.
     Clean 'em regularly by the book or more.
I think you have to balance the risks of a new failure ...
If those backup's ain't mission critical, or you have a backup drive ...
see no problem.
If you need the backups badly, and ALL your (capable) drives are subject
to a sudden unexpected failure with no spares or "one day changing" :
it spell's : TROUBLE.
By the way: my 14 DDS2 (Compaq turbodat 4/16 - Seagate built)
with more than 3 years of use were substituted for being obsolete
(capacity, speed, and "read-after-write"/no-verify) but were ALL
still operational with no "unexpected failures", no "thermal damage",
no degradation in speed or reliability, given the recommended cleaning.
That's what I expected from HP's drives and couldn't find.
Don't have the same data on Sony's, but they seem more rugged,
and had no failures in 9 months.
Well, hope I've helped.
Regards,
Celso Starec.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
HP has a pretty good return policy.  When we bought the drives they came
with a three year warranty.  They have been replacing the failed drives,
usually overnight.  I only have about nine months left on the warranties
though.
I get between  4GB-5GB per hour backup throughput so I think the drive is
being well fed.
Solution #3
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Just can't tell how pissed of I'm with HP.
I had high regard for the company, but they seem to cover this ...
I Had a batch o 4 Compaq DAT 12/24 - HP Built DDS3 Drives - like the DAT
24.
I used them for less than 8GB a day backup's.
All went dead!
The first some 15 day before the end of the first year (and the
warranty,
which is shorter down here in the tropics - Brazil) and Compaq changed
it
immediately (by a Sony built unit).
The second and third both were gone some 30 day after ... 15 day before
Compaq's said the warranty was over, but as they couldn't explain what
was
happening, somebody there gave order to "extend" the warranty and after
some days I've got them changed for working ones (HP Built again).
In the mean time we bought some 10 new units and - thanks god - they
were
all Sony built and are working all right (@ 8 GB/day ==> < 2.5 hs/day).
The fourth drive os the batch, which was backing up only
4 GB/day ==> 1-2.5 hs/day (backup or backup+verify)
is gone also with an year and a half of use.
Compaq won't say nothing. I wanted to have knowledge to do some
predictive analysis as it is to stressful to have a multiple
failure making wreck of any contingence planing.
HP say absolutely nothing in it's site, or it's support forums.
Now and then people complain about it.
I've hear of thermal damage in the heads caused by high duty cycles ...
May be 4 GB/day for a DAT 24 is just too much!
HP has a spec for 12% duty cycle (12% of 24 Hs is 2.9 Hs !).
They should call it a toy, not a torture tested enterprise solution.
Not all Drives are so unreliable. The ones from Sony are just working
fine.
I have some 2 other HP built drives used in less then 2 GB/day ==>
<30min,
not from the same batch, that are still working.
Can I trust them for heavier loads ?
With an 8 hour duty cycle a day, even changing drives won't help.
You should note that the DDS3 and later DAT drives have the
"read-after-write" feature, and the drive retries up to 255 times
till writing ok or giving an error; and when the backup seems ok it is
ok.
(I've done a lot o testing to check it!)
May be you can verify only from time to time, and the duty cycle is
halved,
giving you better reliability overall.
You should also check if the drive is streaming. I get from 3 to 6 GB/h
with those drives depending on the system load and small file/empty dir
load.
if the  tape isn't streaming the tape will "shoe-shine" the magnetic
heads
shortening even more their life.
In case you use Sbackup in nw 4.x, optimization IS BADLY needed.
Let's open a SIG on HP's bad policy of covering up the faulty history
of it's toy/enterprise-stressfull drives, instead of doing a recall.
They should know if all the drives are bad, or just some of them.
And we should be told the real reliability we are buying.
Well,
Solution #4
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Hi!
I've used my HP DDS3 drive 5 days a week, backing up 16 gigabytes whith
verification. It works fine near 2 years and 6 month and then dead. HP
warranty is 2 years and better solution is get new device. In Your case
You may have 3 years of warranty (Your device is newer) and may be You
need to contact HP?
Regards,
Alexey
Can you Help with these Removable Media problems?
Removable Media
Floppy Drive Message:...
I'm getting a mesage when I try... Answer This...
Removable Media
Identifying what TYPE of PCMCIA...
Im talking about an Akai XE8... Answer This...
Removable Media
matsui dishwasher mf160
power lights comes on then... Answer This...
Removable Media
usb device not recognised
i have 1 gb kingston... Answer This...
Repair Service
Find Removable Media Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
