Question about Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
Freezer does not work
I bought a second hand freezer and pluged it in after 2 1/2 hours. It worked first but it stoped working. It does not operate at all. The wall breakers and outlet is working. Whenever I try to put the electric cord in the outlet, the reset light went on.
  • 40 Answers
Re: freezer does not work
The unit may be stuck in a defrost mode.Check the timer.Turn the knob to take it out of defrost.The unit will start up when this is done and the defrost timer is the culprit.
Posted on Dec 14, 2007
0 characters
3 Points
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
Black & Decker BF53 Chest Freezer wont freezer after moving to another state. It worked fine and now its just freezing to a frost is all. I'm scared my food is going to spoil. Bought it second hand and...
dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Jul 09, 2010 | Freezers
Kenmore chest freezer wont cool
Here is a tip that will help you...
There are also more tips at the bottom of this one...
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Jan 30, 2009 | Freezers
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Thermadore Freezer
I assume you mean do not work? I have the freedom 18" with through the door ice water. Themador has replaced the whole unit already. The second stoped woking after six weeks, call is in to repair again......
Mar 21, 2008 | Thermador Freezer FREEDOM® T24ID80PLS
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
288 people viewed this question
Top Frigidaire Freezers Experts
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
