Question about Canon imageCLASS D320 Digital Copier
I have a Sharp AL-1642CL printer. It will not
I have a Sharp AL-1642CL printer. It will not pickup paper from either tray. It will pickup from the external paper tray.
  • Canon Master
  • 1,294 Answers
Check the paper tray sensors or change the set to external by pas tray to paper tray.
Posted on Aug 02, 2009
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Jul 21, 2009 | Sharp Office Equipment & Supplies
"P" is blinking. There is no paper jam. Paper is not feeding from the paper tray.
Hello sir; there is paper pick up roller dirty or worm, need to clean or replace.
Apr 28, 2009 | Sharp AL-1451 Laser Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Jun 11, 2008 | Sharp AL-1642CS Copier
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Sharp al-1250 wont switch from tray 1 leter to tray 2 legal when printing
On the control panel there should be a button that either says paper select or looks like a bucket with lines in press this and the machine will change paper trays.
Thanks J
Dec 11, 2007 | Sharp AL-1250 Laser Printer
Canon imageCLASS D320 Digital Copier Logo
old marine
old marine
