Question about Welding Tools
Lincoln SP-180T. Spits, sputters, stubs and unstable arc
Lincoln SP-180T. The unit was delivered with a bad trigger which Lincoln replaced. Since replacing the trigger it has worked great up until now. Now, all of a sudden it spits, sputters, stubs and will not maintain a stable arc especially on lower tap settings like A & B. Polarity is correct for C-25 and as near as I can tell the ground is good.
  • 850 Answers
Mabe low argon pressure
Posted on Jul 20, 2009
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
What would make my 1995 Lincoln Continental make a roaring sound in the front end when it is driven?
it could be bad tires,bad wheel bearing,or the power steering pump? Not enough INFO to answer completely
Mar 23, 2010 | 1992 Lincoln Continental
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Lincoln SP-135T Does nothing Please HELP
Its a troubleshooting job, you'll have to use your voltmeter, and perfom tests on the unit to find the proble.
Oct 26, 2009 | Lincoln Welding Tools
2006 lincoln zephyr cd player won't play cds
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 27, 2009 | 2006 Lincoln Zephyr
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
My lincoln welder/generator Ranger 8 will not idle up when stricking an arc, it will idle up if I plug in a drop light.
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
May 07, 2009 | Lincoln Welding Tools
Welding Tools Logo
774 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
