Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Red light fashes 6 times
Like it says red power light flashes 6 times, the lamp light is not on, I removed the rear cover and checked the glass fuse but it looks good, how much should I spend to get it fixed?
  • 1 more comment
  • johnboyjohng Dec 20, 2008
    I have my t.v. all apart and I cant get the back off or the light tray out to change the thermal fuse can anyone help me modle # KDF-60XS955 thanks johnboyjohng@yahoo.com
  • rmatos Dec 31, 2008
    my tv blink green 5x and then red 6x can someone tell me whats wrong before a spend a fortune trying to fix it
  • HenrikN Jan 04, 2009
    I have that same problem and I need to change the thermal fuse.
    Does someone have the Service Bulletin about this?
    Thank you in advance,
    Henrik Nicolaisen
I have the back off and cant find where the bulb is at
Posted on Dec 29, 2008
    Novelist:
  • 111 Answers
Six blinks=no horizontal (H STOP), no raster, goes to the blinking self diagnosis function immediately. check the horizontal circuits, not sure what the repair will cost you.
you can try this to reset the tv to manufacturer defaults, but there is no guarantee it will clear the problem. to do this, with the tv in standby, quickly press "display", channel "5", volume "+", then power. once the service menu is up, press 8 and then enter, and lastly the power button.
this should reset to factory defaults. once again, no guarantee this will help, but the no horizontal (h-stop) diagnosis should give you something to ask the repair techs about over the phone to get a rough estimate of repair cost.
Posted on Nov 17, 2007
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
TV will not power on, green light flashes 6 times
Either you have a defective Lamp or your Ballast Board has went out It is what turns on Lamp CK out Encompass Parts Distr online type in your Model number then it should list all the Parts for your TV or Call them 1-800-638-3328 also make sure Fan to Lamp is working if it stops running Lamp will not light.
Dec 01, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
Jan 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
