Question about Akai PDP4225M 42 in. Plasma Television
Cable how do i connect my cable from the wall to my pdp4225m when it does not have a cable jack?
  • 1 more comment
  • Zareef Nov 25, 2007
  • alexi7631 Mar 06, 2008
    Where is the connection for the cable?
  • 515gregs Dec 11, 2008
    How to you connect the Akai pdp4225m plasma to the outside attenna for regular tv viewing
    Problem Solver:
  • 4 Answers
Try setting up a vcr and then using the rca jacks for the connection. the cable will run thru the vcr as well as the channel changes
Posted on Dec 10, 2008
  • 22 Answers
Your cable provider should have gave you a ribbon style wire to scart, do you have one? and if not try your cable supplier. I have Virgin cable and have the correct wires on fittment.
Posted on Mar 06, 2008
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
How do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
Dec 26, 2010 | Nikon Coolpix S3000 Digital Camera
I cannot send faxes on my HP 700. When I call my fax number it does not ring or answer. The unit is plugged in and the screen has normal information. It does print out sending failures.
If your fax does not ring when you call the number then it is not properly connected to the phone line.
Try checking the connections on the fax and to the wall jack; make sure the phone cable is connected to the correct jack on the fax machine.
If this is all good and still no ringing, then you should try another telephone cable or try connecting the fax to another phone jack. The modems and jacks on fax machines rarely break down but if you have tried different wall jacks and different phone cables then you can finally assume that the fax machine is broken.
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I have a Akai PDP4225M 42" Plasma and I want to mount it on the wall, what type of wall hanger do I need. Thanks Pat
I found the wall mount for your Akai. check link.
http://www.dealtime.com/xDN-tv_accessories--akai
Apr 20, 2010 | Akai PDP4225M 42 in. Plasma Television
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
Telephone wall jack
Did the old wall jack work before you removed it?
Are the wires still connected or do you remember where the wires used to go.
If so, then what I would do, is with a phone connected, start disconnecting 1 wire at a time. When the line goes dead, then you know that is one of the wires that you need to use. Reconnect that wire, and mark it, and Keep doing this until you find the other wire that makes the line go dead.
Then you will know which 2 wires you will need to get the jack working.
Usually, the standard color wires that you need for the new jack is Red and Green for a single line phone jack.
Hope this helps.
Good luck.
Mac
Feb 21, 2008 | Lands Phones
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Pdp4225m
this is a monitor only, you need a cable box to use a the tuner.
Nov 25, 2007 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M 42 in. Plasma Television Logo
115 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
