Washer not spinning with full load
My washing machine is not spinning with full load but does when the machine is empty/no clothes
  • 92 Answers
Check the motor bushes.
Posted on Jul 15, 2009
Spins when empty. Why not when full?
When the machine is full, the built in sensor triggers a switch to let the machine know there are clothes inside. Check the sensors and/or switch, as they may be faulty.
Jan 03, 2016 | GE WBSR3140DW Top Load Washer
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Washer quit the spin cycle
If the machine will not wash or spin, but will still pump the water out, you probably have a broken coupling which connects the motor to the gearbox. This is a simple job for an experienced tech, and should not be expensive...good luck....Nomess
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
