Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Unable to print
Flashing E and 3 and wont let us print,it says removed jammed paper but we cant see any paper stuck
    President:
  • 2,306 Answers
If the paper sensor tab is broken you will need a shop to repair. Many times when a jam is removed the tab is broken off or the lever is pulled out of position. Hopefully you can take advantage of the one year warranty..
Posted on Jul 14, 2009
Paper is stuck/jammed on the drum and I am having difficulty removing the d rum unit and toner
Hi lbestu,
Please Read Tip Carefully :-
Tip: To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
Am getng an eror 3 which is regarding paper jam in printer canon140 mp but der is no paper jam in printer.. need help...
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Oct 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam on my i560
there is a small paper very small paper stuck in the printer remove it it will work
Nov 09, 2009 | Canon BubbleJet i560 InkJet Printer
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Wont work at all just says unable to print 36
"Machine Error 36" and "Unable to Print" are error messages indicating something physically making it impossible for the machine to work. Hopefully, you could find a stuck paper or parts of stuck paper by opening the different covers (front, back, paper trays etc), the problem should then be solved by removing the paper and rebooting your machine.
However, if this does not work or you're unable to find the stuck paper, you will need to have service on this unit, to open up the machine.
May 17, 2009 | Brother MFC 6490CW InkJet Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
I cant print
i need software for my hp deskjet 3745 printer
Oct 21, 2008 | HP DeskJet 3745 Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
119 people viewed this question
old marine
old marine
