Question about Hitachi 43FDX01B TV
Digital Array? My Hitachi 50GX30B rear projection Tv has a blue line that runs from the top right corner to the top left corner and goes down about a 3rd of the way of the screen, looking like a smile on the tv. The digital array will not converge and line up the blue color. Any help appreciated. Cannot adjust digital array. Blue is way out of whack
  • 934 Answers
Re: Digital Array?
Replace IK04 and IK05, both STK392-110, but use instead STK392-150's for greater reliability. And don't get some Chineese knock-offs - use original Sanyo replacements. If you don't know where to get those try ACME Enterprises in Florida,
Also measure the low ohm feed resistors in that circuit. However usually just replacing the convergence amps will restore normal video...
Posted on Nov 17, 2007
0 characters
3 Points
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site only
Nov 26, 2007 | Curtis CM19033S 19" TV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Hitachi projection model #43fdx01b.distorted color, blue off set. Half moon line at the top, taking top part of picture.
Ur convergence is dead.U need buy a convergence kit,U know how to solder right?Buy it at these websites.Tv Repair or
Sep 30, 2009 | Hitachi 43FDX01B TV
Tv's picture is messed up.
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vert movement.
Cause: Replace IK05 (STK392-110) and RK54 (1.5 ohm/1W) and converge. RK50(2.2 ohm/1W)
Sep 20, 2009 | Hitachi 43FDX01B TV
HITACHI ULTRASCAN HD TV w/Model # 43FDX01B (Digital ProjectionTV)
i am not sure these is going to work but give it a try. after useing the tv for a long time you can get a problem with the lineing of the three picture colors may drift away from each other causeing the problem you have, they move because of moveing the tv or the viberation of the tv.  you can to one of two things if you have a remote for the tv go to the menu and look for the convergence adj. setting then you are going to get close to you tv and press the small but the says the same thing now on the screen you are going to see a grid the you can fix youself with the remote just by pressing the up, down,left, rigth buttons and the menu button to change the color, to aline the red line and blue line with the middle line till you get only a white line going up and down  if the doesn't work just unplugg th power cord and what for about 4 hours and then plug it in and turn it on again. if after you do all these if you still have the problem then you either have two choices call to see how much it will cost to repair it or toss it out and get a new one
Mar 19, 2009 | Hitachi 43FDX01B TV
46 inch hitache projection tv
sounds like the bulb has gone, go to your local tv store and the should be able to get you a replacement.
Mar 10, 2009 | Hitachi 43FDX01B TV
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
Hitachi 43GX01B 43 in. Rear
please contact the nearest repair need to be qualified to repair it!!!
Jul 31, 2008 | Hitachi 43FDX01B TV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
103 people viewed this question
Top Hitachi Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Standard (CRT) Television Expert? Answer questions, earn points and help others
