Question about Dell Dimension 3000 PC Desktop
Added 1GB of memory and when I turned PC on it made the sound that the mountain does on Stargate SG-1 when they go into high alert! Bonk, Bonk, Bonk! Any ideas?
  • Anonymous Mar 30, 2014
    bonk bonk sound every 5 seconds from my computer speakers
    President:
  • 846 Answers
Hello Gmhoopau,
I'm not familiar with your description of the sound but can you verify for me that the memory you are using is compatible with the motherboard ?
=PC SPECS=
* 333- and 400-MHz DDR Memory
* 128mb, 256mb, 512mb, or 1-GB nonECC modules
* Maximum memory 2 GB
Can you post back with the details of the memory you put in (most of it should be on the sticker if there is one on the modules. Chances are if the memory type, or size is incompatible then it may cause your PC to function improperly perhaps even causing (BONK BONK BONK) sounds.
Post back with any questions or comments for further assistance. Thank you for choosing Fixya!
Posted on Jul 14, 2009
What the episode or the alien is called that is a ble to put its hand into jack and john's head?
All the episode in which Hands are placed into Heads by replicators are: Stargate SG-1: Unnatural Selection, New Order, Part 1, New Order, Part 2, Reckoning, Part 1, Reckoning, Part 2 Stargate Atlantis: Progeny, The Return, Part 2, Lifeline, Ghost in the Machine
Sep 04, 2016 | Stargate SG-1 (1997)
Adding Memory to Inspiron 546
Try them in slots 1 & 2 also make sure your ram is all the same .Also try 1 at a time you may have a faulty ram module. .
Jan 17, 2014 | Dell Inspiron 546 MT Desktop Computer
Added a 2gb ddr2 to top up the 1gb but now I only get a bleeping sound.
Hello you can download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=653
Try to clean the mainboard for dust with compressed air
and let your dealer search the ram module for a defect.
The spec. for the ram is this:
Number of Memory Slots2 240pinMemory StandardDDR2 800Maximum Memory Supported16GBChannel SupportedDual Channel
You have maybe not insertet the ram correctly.
Good luck
Oct 24, 2012 | ECS C51GM-M Motherboard
PC slow even with new RAM
Adding hardware might not be enough to turn around the issue. There are a number of reasons might be affecting your PC's performance, some are dangerous while others not that serious. Learn why is your PC running slow and how to speed it up easily from: http://www.whyismypcsoslow.net/
Jul 08, 2012 | eMachines Computers & Internet
I added a new ram before it has a 1GB and now i added another 2GB of ram.when i turn on my laptop it says there installed memory is 3GB which is right,but the problem it says also that 1GB usable..its that...
assuming your running th correct memory modules(same clock speed and size) you ahould have more useable. switch the larger one out to the nexxt slot and see if that fixes it. if not then just use the 2 gb by itself. this is more than enough for windows 7
Jan 19, 2011 | Compaq Presario M2000 Notebook
Today without any warning, after i started my pc, when it load until the window loading screen, suddenly the screen turn pitch black & a loud continuous beeping sound was started. I tried to trace...
Try it with 1 gb memory if it still beeps, try it on a different slots. if it works with 1gb turn off the pc, slowly add the other rams then test
Aug 23, 2010 | Computers & Internet
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Can you mix 1gb and 2gb dimms in the same machine (for a total of 6gb)? I added two 2gb 1066 DDR2 dimms (''OCZ'') to a PC that already had two 1066 DDR2 1gb dimms (''Kingston''). I moved the 1gb dimms to...
Your MB is AM3 with 128MB DDR3-1333 built-in, four 1.8 Volt DDR2-1200+ depending on cpu. Have you enabled cpu 64 bit extensions? Tried slowing down your memory bus?
My ASUS use dual channel for dual core cpu. I have 2 yellow and 2 black dimm sockets. Both dimms in yellow is single channel, one in yellow and one in black is dual channel. Might try 2,1,2,1 rather than 2,2,1,1 order. If only your 2 1GB dimms are seen then why do you get 4 GB from 1GB+1GB? Sounds like sockets 1,2 are giving you 4GB and 3,4 don't work? Are the 1GB+1GB in 3,4 visible if the dimms in 1,2 are removed? Per Gigabyte page your AMD Phenom II 920 is AM2+ : "Note: Due to AMD AM2+ CPU limitation, memory module DDR2 1066 or above speed is only supported by 1 dimm per channel." Per AMD (which does not show your cpu, AM3 cpu fit AM3 or AM2+ socket and support ddr2 and ddr3, AM2+ cpu only work in AM2+ socket and support ddr2 only.
Oct 16, 2009 | Computers & Internet
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
Dell Dimension 3000 PC Desktop Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
