Question about Dell (074JH) Internal 48x CD-ROM Drive
COMBO Drive cannot eject
MSI product. when i press the ejected button it stuck up. it cannot open the cd holder. how i can fix this problem?
    Problem Solver:
  • 14 Answers
Re: COMBO Drive cannot eject
On most cd drives somewhere below the tray is a small hole. Unfold a paper clip and stick it in there and press until the CD tray pops out. This dislodges it from the motor so it will not pop out all the way but it should be enough to get your CD/DVD out of the drive. Once that is done press the eject button to close the CD drive and "re-hook" it to the motor. If you are running an operating system other than windows such as Ubuntu, it will disable the CD drive eject button when in console mode, in which case you can just type eject to eject the CD drive.
Posted on May 01, 2008
  • 47 Answers
Re: COMBO Drive cannot eject - Dell (074JH) Internal 48x CD-ROM Drive CD Drives
Pls clean the cd-rom
Posted on Mar 13, 2008
0 characters
3 Points
Eject a stuck CD
Barbara sometimes lightly banging on the drive and pressing eject button at the same time may diengage the CD. It must be a copied CD.that acts this way.
Aug 15, 2013 | CD Drives
It cannot open or eject the drive
If there is something stuck in the drive and you need to get it out, there is a tiny little hole on the right side (beside the eject button). Just take a paper clip and stick it in there. You will hear a click and the drive will unlock and eject.
For operational use, does you computer see the drive in My Computer? I would open the case and take a look to ensure that the cables are all tightly plugged in.
Nov 25, 2010 | Samsung SC-152L (dssm52xcdoem) Internal...
Cd is stuck inside
Straighten a Paper clip and push it into the small hole (usually below the eject button) while you press the eject button, it'll come out. Note that you'll need to push in the pin with some force. You can also use a long needle. Good luck. Thanks for using FixYa.
Jun 06, 2010 | Dell (6T980-A01) CD-ROM Drive
CD stuck in emac drive.
yes you can but be sure to be careful because if some parts get dirty it will not work. Hope this helps!?
Please rate solution - Thanks.
Apr 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
The CD rom tray will not open.
just watch carefully on cd drive front there is a tine hole somewhere below the door area . now u need a very thin rod or something to insert in to it. there is a button inside that hole so while pressing that button press the eject button. hopefully ur cd drive door will open
Apr 20, 2010 | IBM -3509707 External 4x CD-ROM Drive
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
Audio cd placed in cd drive is stuck; drive won't open. How can I get it open?
Next to push button here is a tiny hole. Insert a small pin through it a nd press the lever. It should open
Open the music programme there in your computer. On the drop down menu click on EJECT and CD drive should open.
Dec 08, 2009 | HP Pavilion ZE4400 series: 1170B01-90...
My cd drive doesnt open
near the eject button of ur cd drive there will be a pin hole insert a pin inside and the press the eject button on the cd drive while pressing the pin
once the cd tray is out place any old cd inside the cd tray with the shiny surface facing upword always place this cd inside and u will never face the problem
Jul 10, 2009 | Toshiba CD Drives
The CD ROM Drive is not ejecting properly
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | CD Drives
My cd rom is stuck, when i click eject button it won't open.
There should be a small hole in the front, use a paper clip and push into the hole to eject tray mannualy. The cause of the tray not ejecting is that the belt from the motor that ejects the tray is worn, need to change it.cheers.
Dec 01, 2008 | Gateway (5502156) CD-ROM Drive
Dell (074JH) Internal 48x CD-ROM Drive Logo
257 people viewed this question
Top Dell CD Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
NewYork kyocera HP...
Are you a Dell CD Drive Expert? Answer questions, earn points and help others
