Question about Sony Handycam DCR-TRV350 Digital Camcorder
When camere mode is on I can see on display vertical lines and unfocused view. That's look like problem with optical sensor or something like this. Can you help?
  • 125 Answers
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Posted on Sep 25, 2009
Sony model KDL32L5000 has a black horizontal line across the display. above the line picture is fine, below the line display is distorted... any ideas?
Faulty vertical deflection section. check the yoke vertical winding. maybe its cure from service mode. search online how to apply service mode of you tv brand, model and board chassis number.
Aug 17, 2014 | Televison & Video
Lumix DMC ZS30 vertical lines on display. Is it display or something else?
Since the pictures are ok, it doesn't appear to be the sensor. What happens when you bring up the menu? Do you see the lines then? If so, then it most likely is the display.
May 07, 2014 | Panasonic Lumix DMC-ZS30 Digital Camera...
Getting red vertical line on LCD panel
Do the pictures have the same line when viewing them on a PC or other device? If so, great chance your camera sensor or the connection to is is dammaged. If you only see it on the display, the display is dammaged, but you still can us the camera to shoot pictures.
Nov 02, 2013 | GE A730 Digital Camera
I have vertical lines on my monitor and cannot make them disappear through any settings ? can anyone help
When does it appear on windows or before
If in Windows then uninstall the drivers of Display Adapter
Steps :-
Right Click my computer -> Manage -> Device Manager -> Display -> Uninstall -> Restart the Computer
Still Nogo
Update the Drivers of Video or display from Internet
Check if u can see same lines in BIOS Mode
Steps to go into BIOS
Restart Computer -> Keeping tapping F10 Key its a single Key on First Row of Kayboard
Check in that mode if u can see same lines over there contact View Sonic Hardware Problem
Jun 01, 2010 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Got a sc141 and 142 on a ricoh mp5000. Have cleaned the lamp and associated mirrors and have reseated the connectors at the lamp and sbu. i have run the scanner free run with the lamp on. there is no...
SC 141 -Lens vertical home position sensor abnormal stays on
When the lens returns to the home position the lens vertical home position sensor does not detect the off condition.The possible cause :home position sensor open,lens vertical drive motor defective or optics control board defective.
SC 142 -Lens horizontal home position sensor abnormal stays off
When the lens returns to the home position,the lens horizontal home position sensor mot detect the on condition.Possible cause :home position sensor in shortcircuit,horizontal drive motor defective or optics board defective.
The SC can be reset by turning main switch OFF and ON if the SC caused by misdetection.
Scanner free run
Remove the rear cover and the air inlet duct.Remove CN502,CN503,CN504 from the optic control board.Create short circuit TP 514 and GND on the optics board.Turn ON the main switch.Short circuit TP 512 and GND then the machine automatically starts the scanner free run.Turn off the main switch.Perform the scanner control adjustment.Enter in the service mode:press the clear modes key - 107 -press the clear/stop key more 3 second until the service mode appears.Perform the free run test mode 30 times.
Sep 19, 2009 | Ricoh Office Equipment & Supplies
Sony WEGA has multicolered vertical lines
OK, much as I have reservations, let's try service mode. To enter service mode, you MUST have the original Sony remote. You need to press these buttons in order, with the TV off. You have about 2 or 3 seconds to complete the series of buttons. Press:
Display
#5 (the 5 on the number keypad)
Vol + (volume up)
power
Then, after the screen is lit, press the "jump" carefully 3 times. If the word "penle appears in the upper left corner, the optical block is OK and it's probably a Q-box problem. It COULD also be the LVDS cable that sends the signal to the optical block. If you press anything else, IMMEDIATELY TURN THE TV OFF AND START AGAIN. The TV should reset to the original values.
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lines appear on photo's.
Hey Tia Cindy,
If the lines are vertical that is often a result of taking pictures of very bright subjects. This is aberration is called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician such as bringing it to a Geek Squad® precinct in a Best Buy™ store, and they will send it out to have it looked at. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Olympus FE-190 Digital Camera
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
Jan 02, 2008 | Zenith P60W26 60 in. HD-Ready Plasma...
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Sony Handycam DCR-TRV350 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
