Question about Mitsubishi WS-65511 65" Rear Projection Television
Blue converge unable to adjust. what is stk? and where is it located?
  • 934 Answers
STK refers to a Sanyo style Ic, in this case your Tv takes a STK393-110 at board location Ic8c00 Mits p/n# 267p155010.
If you don't buy from MDEA make sure to get Sanyo originals from a trusted distributor like ACME Enterprises in Florida. If you're going to attempt this youself you'll also need a good soldering station (like a wes50), a DMM, some heat sink compound and alot of patience.
Use the DMM to test the value of the low ohm resistors that feed those amps. In this case, blue being bad, my guess is you'll find R8c21 & R8c22 (3.9 ohm 1 watt) changed in value or nearly wide open. But check all the 3.9 ohm resistors in that circuit.
The STK393-110 is a multi-layer / multi-pin Ic on a large aluminum heat sink. You'll want to have the patience of Job to extract and insert the new one. Bend the pins too badly and it can make the task ten times more difficult.
Don't hold the solder tip on these too long and don't be in a big hurry to solder them all in one sitting. Solder and couple and give it a few seconds to dissipate heat...
Hope this helps!
Posted on Nov 17, 2007
Currently, the red and blue color alignment is off and I am unable to adjust this. There is a red shadow with a blue hue. Have tried to realign the colors but can not get the red to move.
Ur tv have a convergence problems,it dead.The convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to get ur convergence back to normal.The shop will u $300-350 for parts and labors.
May 25, 2010 | Philips Magnavox 51MP392H Rear Projection...
Can't adjust blue vertical convergance.
blue vertical is defective convergence amplifier Stk ic and need to replace
Jul 08, 2009 | Philips 55PP9401 55" Rear Projection...
Hitachi convergence issues
This is a convergence issue
Try to visit this site
Jul 08, 2009 | Hitachi 60EX38B TV
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue Convergence
go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
Jan 06, 2009 | Mitsubishi WS-55513 55" Rear Projection...
The Blue and Yellow colors on the left half of the screen(looking at TV) will not adjust correctly. Sony Rear Projection HDTV-Ready TV about 7 years old...
its the problem of convergence on your resolder convergence STK ic's. if that does not work, change (STK-ics).
they ar located on the main power supply board and there are two such ics on the board replace both the ics.and easily available in the local electrical shop.
Sep 24, 2008 | Televison & Video
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Phillips 60pp920217f My TV has a problem with the red and blue convergence. I am unable to adjust
The problem you are having is with your convergence amps your set uses STK 392-120's if you replace them you will get your convergence adjustment back, Philips part number is 932212344682
Aug 13, 2008 | Televison & Video
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 50" 50GX30B PJTV
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
