Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
My problem is that too much water is coming out with the shot of espresso. When I choose a "small" or sgl shot, the machine will overflow the shot pitcher. Thank you for any help you can give.
    President:
  • 1,618 Answers
To reprogram hold down button through complete cycle until desired amount is reached.
Posted on Jul 15, 2009
Are there different types of espresso coffee?
The classic form of espresso is a small shot (2-3oz) of pressure brewed coffee made using about 1tblspn of finely ground coffee. There are several ways in which this original format has been altered to come up with various types of espresso coffee drinks. Here is a short list of some of the more popular varieties:
Americano - espresso with hot water added to dilute the strength
Macchiato - espresso shot with a small amount of frothed milk on top
Corretto - espresso mixed with a bit of alcohol
Cappuccino - a shot of espresso topped with 1/3 steamed milk and 1/3 frothed milk
Mocha - a latte with chocolate powder/chocolate sauce added
If you would like to know more about espresso, please visit the link below.
http://www.1stincoffee.com/what-is-espresso.htm
Feb 07, 2013 | Wine & Spirits
Water overflow
outlet behind the brew unit could be plugged. This will cause water to spill on counter from behind the tray. Clean out this small hole with a q tip or squirt water from a syringe into it and from above it through the plunger window. It should run clean. This is where the excess water is supposed to go into the tray
Nov 26, 2012 | Solis Master 5000 Espresso Machine
It produces only very small amounts of coffee
If it is an espresso maker, a single shot is only 1.5 onces. I know a lot of the DeLonghi's come with two different size filters for the espresso. If you use the small, you should only expect about that much, if you use the larger it will be about double (still less than a quarter cup). Even though it is very little, espresso is very strong. Either add water to taste for an Americano, or steamed milk for a Latte.
Mar 06, 2011 | DeLonghi Coffee Makers & Espresso Machines
My machine mark alternativley ventilate and fill water tank. I ventilate and I fill the machine and the message don't dissapear. With this display, I can't make any coffee. My email :...
Remove the bottom of the coffee maker, identify two rubber tubes and check to see if one has come loose or is simply not on tight. A simple reattaching of one of the tubes will work.
Another reason could be draining hole getting clogged with coffee grounds. When this happens it is easily fixed by removing the brew group and overflow tray; find the small drain at the back that drains excess water into the overflow tray and opens it up with a pipe cleaner or tooth pick. Flush out any coffee ground behind that hole.
Hope this helps.
Shane
Mar 06, 2011 | Saeco Spidem Trevi Digital Plus Fully...
No steam or hot water
Check to make sure pressure is coming out of the wand, if not, there is definately dried up clog inside the tube somewhere or possibility that the hose is loose on motor.
Jun 18, 2009 | Saeco Incanto Classic Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
May 21, 2009 | Waring Pro® WC1000
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
www.cerinicoffee.com
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
127 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
