Question about McCulloch FHH18A Electric Pressure Washer
Where can i get a new hose for a1600 psi jet washer? Hose has a leak in it and we are not having any luck finding a replacement locally. Washer was purchased at either walmart or Canadian Tire.
I have an older Karcher Pressure Washer and I am unable to find the model number. This is the info that I have: 79C2, Volume 1.9, Pressure 1400, Serial # 800983493B, 120 Bar, 60 degree C,
QC506-877. I need the model # to order a replace gun and/or wand. thank you
Posted on Jul 14, 2009
Blocked washer jets
Find hose that goes from pump to hood ,should be a connector inline somewhere. Disconnect hose and use air nozzle to blow back through jets
Mar 19, 2015 | Cars & Trucks
Why does washer leak excessive water?
Some times the power washer are made poorly. If the leaks are at the hose connection you can replace plastic with a better one made of brass and the use of Teflon tape. Good luck
Sep 08, 2014 | FAIP Powerwasher Pw1400z 1,400 Psi 1.5 Gpm...
My washer is flashing LF
LF error code indicates that there is a water supply problem.
Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked? Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe? The drain hose may be too far inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shaped drain hose form as described in the Installation Instructions will provide the appropriate length of drain hose in the drainpipe or laundry tub.
Check it and keep us updated. remeber to rating this free answer and leave some testimonila comment.
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a simpson G3000 pressure washer. The small high pressure line from the pump has developed a leak, (it's about 18"s) Do you have a part number I could use to get a replacement, or point me...
You can use a universal hose for replacement. This hose should not be under high pressure (usually inlet water hose pressure). This is a bypass that is used when you release the trigger to wand. Look closely at the brass fittings of the hose, sometimes they can be reused by removing the clamp and cutting off the rubber part. Use automotive rubber hose (suitable for hot water system/radiator )or black pressure hose from Lowes (sold bulk) that will fit snugly on the barb and use simple clamps. You can make new hose by buying barbs and hose from Lowes or hardware/plumbing store. Good luck
Sep 13, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
I am looking for a replacement hose for my Blue Max pw2200/03435. Does one exist? If so, where can I get one?
Here is a site that shows the lightweight blue max power washer hose
http://www.shopping.com/Psi-Blue-Max-2200-Psi-High-Pressure-Gas-Power-Washer/products
It looks to be a right-fine chinese product manufactured using the technology we paid-for and developed over the past 50 years and then gave away with our jobs overseas.
If you bump up to professional power washers..
Power washer hoses are interchangeable as long as the quick-connects on end of hose can unscrew.
We used power washers a couple times a week. When I needed a new hose, I went to the hydraulic hose shop. They make steel-wound hydraulic hoses for tractors and heavy equipment.
Search 'hydraulic hose in Your-town-your-state'
If the quick-connect ends of the Blue max hose do not come off, check the quick-connect end attached to machine. If it comes off, you can buy a new gun and hose. If the quick connect on the blue max machine does not come off, then the life of your machine is directly related to the life of that single quick-connect fitting.
Search 'power washer guns'
Here's a site with guns like we used
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 15, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Northstar pressure washer needs new hose
Need to know what country you are located in and if you want a 15 foot hose or 25 foot or 50 foot hose. The reason is We have to know where you are going to buy it and if you have a dealer that that is local or not. it's a 2500 PSI hose so the hose has to be a minimum of 3200 PSI You can also have hoses fixed at local hydraulic shops in the U.S. in the local phone book, they can make up the hose you need if you take it to them let me know.
Mar 25, 2010 | Garden
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WIper fluid does not flow
Hi Curran
Usual problem is that the jets nozzles become blocked.
Get a small sewing needle, and clear the jet, preferably when a friend operates the washers.
If this is not successful you will need to pull the feed hose off the jet body, and once again operate to check for blockage or a kinked pipe.
Good Luck !
John.
Jan 16, 2009 | 2001 BMW 330
Leaking power washer hose
most auto stores have high pressure connectors and or machines
to make these connections. Also there are radiant heat connectors
that may or may not fit.
Jul 26, 2008 | Karcher 2500 PSI Pressure Washer
Water leak
Im assuming your leak is at the fill valve entering the washer. Each fill hose has a grommet much like a garden hose. Stop at your local hardware store and pick up some new grommets or replace the fill hoses with a new set. Good luck
Jul 16, 2006 | Whirlpool LSR5132PQ Top Load Washer
McCulloch FHH18A Electric Pressure Washer Logo
325 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
