Question about Emerson MS9700 CD Shelf System
How to fix a Emerson MS9700 Audio System with 6-CD Changer when the tray will come out but wont spin and is not responding?
I tried unscrewing the top part of it and below the cd tray is a silver round thing that wont move. its supposed it turn red when on and move but it doesn't. also want to know how to replace the piece if it is broken.
SOURCE:
SOURCE: Emerson MS9700 CD Shelf System - CD Tray won't open
You have to unscrew the whole thing and take the whole metal covering off and then the inner tray will be displayed and then you can just take the CDs out and then screw the cover back on. Happened to me, and that worked :]
Posted on Jun 07, 2008
I had the same exact problem.  When I opened it up, I found that a small rubber-band in the tray opening mechanism has slipped off.  While it was a simple problem, I caused more trouble by breaking a small switch while I was opening it, so be careful if you do decide to open it up.
Posted on Nov 26, 2008
SOURCE: Emerson ms9700
The disk would not spin. Removed 3 screws holding top "bearning deal" trying to remove it. could not get it off but disk would then spin. Worked even when i put screws back!
Posted on Jul 28, 2009
gopakumarg43
  • 76125 Answers
SOURCE: Have a Emerson 6 chger CD/am/fm system. Do I need the remote to use the CD player?
Buy one universal remote control, which have setup codes for your device. Brand name isn't a matter.
Posted on May 07, 2012
  • 53683 Answers
SOURCE: change radio frequency to infrared frequency for the emerson MS9700
I very much doubt your Emerson unit uses radio frequency for remote control
Posted on Nov 27, 2012
Cd stereo says no disc
The player mechanism may have failed.
Sep 08, 2014 | Emerson EM-MS9700 6 CD-Changer stereo...
My emerson md9700 cd player wont operate, how can i fix it?
Does it power on?
If no, and if you're lucky, you can change the power supply
Oct 13, 2013 | Emerson EM-MS9700 6 CD-Changer stereo...
Change radio frequency to infrared frequency for the emerson MS9700
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
May 06, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
Saying no rdy on cd player (Emerson)
make sure you have a cd and your tray spins when opened
Aug 11, 2009 | Emerson MS9700 CD Shelf System
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
Aug 26, 2007 | Emerson MS9700 CD Shelf System
6 CD Changer tray won't eject
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Oct 28, 2005 | Emerson MS9700 CD Shelf System
Emerson MS9700 CD Shelf System Logo
567 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
