Question about HP LaserJet 4600dn Color Printer
Lines down the paper HP 4600DN
I get magenta lines down the paper when printing color - when it is black and white it doesn't show up. The cart is about 1 year old but is full and I haven't done that much printing. The lines show up on the front and back side of the paper.
    Sergeant:
    Novelist:
  • 192 Answers
The actual problem is that the cleaner stage of laser printing may not be functioning correctly on the drum.
One thing you can do is purchase specific sheets from staples I believe. They are meant to be used in the cleaning cycle of the laser printer. Do this first. If this doesn't work, then the drum needs to be replaced.
Posted on Jul 25, 2009
    Scholar:
  • 104 Answers
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Posted on Jul 14, 2009
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
Where is the option to print black and white only (HP 4600dn)
Open the file or image you want to print.Select File>Print>Print Wizard/Tab opens>Select the printer from drop down list>Click Properties tab on the right side area>Below Color Intensity Area>click GREYSCALE PRINTING.
This work for me so give it a try.
Aug 19, 2011 | HP LaserJet 4600dn Color Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
When printing from the HP color laserjet 4600DN, its leaving tracking lines in the middle of the page. Any suggestions on how to fix this?
Hello, track lines could be caused by a number of components within the printer.
Is it any specific color? Yes - Change the toner of the color causing the lines.
open the front main door, Inspect the ETB for damage. Inspect the fuser for damage. If any component shows damage it will need to be replaced.
Feb 04, 2011 | HP LaserJet 4600dn Color Printer
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    Magenta lines on paper
    You need to change the Magenta Toner. Rebuilt toners often have this kind of problems.
    Feb 27, 2009 | HP LaserJet 4600dn Color Printer
    Streaks though the pages
    Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
    1. In the application you are printing from, click File , and then click Print .
    2. Make sure the printer is selected, and then click Properties .
    3. Select the Paper/Quality tab.
    4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
    Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
    2. Make sure the printer is selected and click Properties .
    3. Click the Color tab, and select Print Grayscale and High Quality .
    Step four: Clean the printheads If the print quality is still bad, clean the printheads.
    1. Make sure the printer is loaded with unused white paper.
    2. Open HP Solution Center .
    3. Click Settings , Print Settings , and then select Printer Toolbox .
    4. Click the Service Tab .
    5. Click Clean Printhead , and then click Clean .
    Step five: Align the printheads If the print quality is still bad, align the printheads.
    2. Open the printer Toolbox , and select the Printer Services tab.
    3. Click Align Printheads . The Align Printheads window opens. Click Align .
    4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
    Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
    2. Open the printer Toolbox and select the Printer Services tab.
    3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
    Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
    2. Press the Setup button.
    3. Press 1 and * simultaneously.
    4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
      • If the Black block has lines – replace the KY printhead.
      • If the Cyan block has lines – replace the MC printhead.
      • If the Magenta block has lines – replace the MC printhead.
      • If the Red block has lines – replace the KY printhead.
      • If the Green block has lines – replace the KY printhead.
    Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    HP L7680 Printer Head Problem
    Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
    In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
    Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
    NOTE:- This step does not apply to color printouts.
    Make sure the printer is selected and click Properties.
    Click the Color tab, and select Print Grayscale and High Quality.
    Open HP Solution Center.
    Click Settings, Print Settings, and then select Printer Toolbox.
    Click the Service Tab.
    Click Clean Printhead, and then click Clean.
    Open the printer Toolbox, and select the Printer Services tab.
    Click Align Printheads. The Align Printheads window opens. Click Align.
    Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
    If the Cyan block has lines – replace the MC Printhead.
    If the Magenta block has lines – replace the MC Printhead.
    Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
    Cannot print in color on HP OfficeJet 9110 All-in-One
    Nothing to do with the driver, I'd say the cartridges are your problem, skipping lines and missing colour are indications of needing new ink carts, are carts new HP ones?
    Jan 19, 2008 | HP Officejet 9110 All-In-One InkJet...
    HP LaserJet 4600dn Color Printer Logo
    488 people viewed this question
    Seeker5211
    Seeker5211
