Question about Samsung LN-S2651D 26 in. LCD Television
Volume stops working then starts again then goes out again.
The volume will be workning fine then will stop for a while, come back then go through the cycle intermitently.
  • 934 Answers
I would guess you have a failure of the sound amp or sound processor Ic, located on the main board.
The two smaller Ic's at the bottom-center of this photo are the audio processor and audio amp...
I can send you a service manual if you like. It isn't a difficult task to replace this board, and the manual will give you teardown instructions. From there just order the new one and install it. If on the oter hand any of this seems like a foreign language take it to a professional.
Hope this helps!
Bill
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 17, 2007
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
TV turns on and volume goes as high as it can. Bring volume back down using buttons and it will come down, but as soon as you take your finger off the button it goes all the way back up. Will not accept...
The buttons on the front of the set fail, (like mine did) even if they never get used. Obviously the 'UP Volume' in your case is stuck closed. Try pecking on it first. My remote stopped working but so did the manual buttons too. While poking around on stuff I swished my finger across the buttons and it all started working again so I knew I was on to something. I never figured out which one was the culprit as it continued to cause problems and was replaced as a complete unit under warranty.
The other quick check/fix is to remove the trim plate around the button plate, then remove the button assembly (3 screws plus pop out stays like the speaker covers) then unplug the multi colored lead from the button circuit board. This puts the Remote back in control and it will work just fine like this, minus manual control of course.
Oct 27, 2010 | Mitsubishi WS-65711 65" Rear Projection...
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
The volume stays on high. I can lower it but, after I release the button the volume goes back to high.
I have the same problem with KV-20-FV-300. My remote stopped working and when I adjusted the volume manually, it goes to high and when it adjust it back down, it goes high again. I'm able to get the sound to stabilize by getting the volume to where I want it, and then pushing the up and down volume buttons at the same time. I'm still searching for a permanant solution though.
Mar 20, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Volume buttom problem
Just o do a soft reset and it will be all fine again. (red button under the battery case) good luck
May 07, 2009 | HTC Touch HD Smartphone
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
PHONE IS POSESSED
Let me ask. Did you drop the phone by chance? If you did, you might have broken the sim card holder. Take out your sim and start up the phone. If the phone loads up fine, it is just as I said, the sim holder. If not, I have no idea.
Dec 12, 2007 | Motorola Mobility RAZR V3
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Samsung LN-S2651D 26 in. LCD Television Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
