Are the condensation grids getting cold? if not that is the problem
To test try turning up the setting on the unit to check and see if the sensor is acting up or maybe the air itself is dryer and there are lower levels of humidity in the actual air. Either way turning up the setting to high should produce some water if not there is a problem with the units humidity sensor and a replacement senson should be purchased and installed.
Maybe the compressor itself is not running. Check the connections to the compressor.
i have a kenmore dehumidifier model 53701 and it was working fine but now no water is collected in the container at all. I used to empty it every other day. what gives?
i have a kenmore dehumidifier model 53701 and it has been doing great but recently there is no water to empty, yet its running..what gives?
