I also have the error code E90
All the display lights are flashing on & off & the machine will not work on any programme setting.
  • 234 Answers
This answer was posted by one of the experts on here. I found it for you :)
E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
remove 2 screws at the back which secure the top,
push the top backwards,
unplug the connectors to the front panel,
vibrations due to unbalanced load may have loosened them,
push them firmly back in socket,
pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
power on,
run the machine empty for minimum cycle - rinse only.
Good luck!!!!
Posted on Jul 16, 2009
Error code bosch model:sms65n02ev
Posted on Sep 01, 2010
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    It is flashing E90
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
    Good luck.
    Jun 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
    Machine flashing E90 and not working.
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
    Jan 16, 2011 | Washing Machines
    I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
    Jan 10, 2011 | Washing Machines
    E20 showing on display, machine still got water in
    E20 is related to the pump and as you say a strange noise is there I would check the filter for foreign objects.E90 is normally a communication problem between the main programmer and the display module.There may have been a fault in the pump which has caused a fault at the Programmer.That model was first produced in 2002 but it is worth checking pump and filter first.If you find anything in filter then clean it out and give it another go the E90 error may have been a glich.Best of luck.
    May 04, 2010 | Zanussi FJD1666W Front Load Washer
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    An error message E90 is flashing on my Zanussi washing machine (wdj1294 I am not sure if this is correct) and beeping. I can't turn off the error and obviously the machine won't start a wash as I also...
    don't know exactly what e90 means but each time it happens we turn of the power on wall switch for a half hour and the problem seems to right itself
    Jul 07, 2009 | Washing Machines
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    252 people viewed this question
    Top Washing Machines Experts
