Question about Canon PowerShot SD600 Digital Camera
Installation of Canon Digital Camera Solution Disk. Ver.28.2
When trying to install the disk, I receive the error message:
"An error has occurred during the installation of Image Handling Library.
Installation has been stopped."
I have tried to install the disk many times, to no avail.
Any clues?
  • w4jls Dec 09, 2007
    Thanks you for your suggestions on solving my problem. While not 100% solved, it was not due to your efforts. Thanks for showing me paths where I could down load some useful programs that I could not copy from my CD. I may have a fluke in my XP OS. Most, but not all problems can be traced back to the operator, I've found. Best regards, Wright Bell
  • 279 Answers
What version of Windows are you installing this on, or is it on a Mac?
Regardless, you can download an updated version of the software here:
It's possible you have an outdated version that won't work with your OS, that's especially likely if you're running Vista. Or you could just have a corrupt version. Either way, the first thing to try is downloading the newest version for your OS and installing that. Let me know if you still get an error message when trying this (and what that error message is).
Posted on Dec 06, 2007
MS vista and MS office 2007 installation
You install disk is corrupt (probably from a scratch on the disk), you can download a new copy to burn, making sure it passes the MD5 checksum after download is complete (and use your key during installation).
Jun 28, 2013 | Dell Computers & Internet
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
WHEN INSTALLIN GOOGLE CHROME IT DISPLAY A ERROR MESSAGE CONTAINING The procedure entry point CancelIPChangeNotify could not be located in the dynamic link library IPHLPAPI.DLL.WAT WE HAV TO DO?
Installation issues: Report installation errors If you're experiencing a problem installing Google Chrome that's not already documented in the Help Center, please help us investigate by using another installer file available at This file creates a more detailed error log during the installation process. Send us your error log when you've gone as far as you could go in the installation process.
You could also try installing an alternate version of Google Chrome that doesn't include the auto-update mechanism, which should make the installation process go smoother.
Jul 02, 2010 | Google Chrome
Many DLL error messages on start up
Your Operating System is corrupted, probably by a virus or a program you recently installed.
The best solution would be to reinstall your Operating System (OS).
Remember to back up your data before OS installation.
Dec 29, 2009 | Microsoft Windows XP Home Edition
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Editing text
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Canon PowerShot SD600 Digital Camera Logo
1,087 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
