Question about Hayward SAND FILTER, PRO SERIES
We have found sand in the bottom of our inground pool we have a hayward pool sand filter what could be the reason
  • 93 Answers
Have you added sand to filter if so may be to much make sure that handle is in the right position check by changing setting several times to make sure sprocket under handle is not damaged sounds likeit is not seated
Posted on Jul 17, 2009
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Gary
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
Hello, when i vacuum my inground pool using a hayward filter....it cleans the pool but the next day sand forms on the bottom of the pool...this was a constant problem last year....what may be causing this?...
If sand is getting back into the pool, the strainer in the filter is broken or out of place. The filter has to be disassembled, sand must be removed and the strainer must be inspected for cracks or leakage. New parts are available from most pool supply stores.
Gary
Mar 05, 2011 | Hayward SAND FILTER, PRO SERIES
I have an inground pool with a Hayward S220T Pro Series Sand Filter. During normal operation, I am getting sand in the pool, through the inlet vents. I am wondering what the problem could be. I suspect the...
You would be correct; replace them with part number SX220DA and you should be all set. If the sand is older than 3 seasons, replace it too while you have to empty the filter.
Aug 23, 2010 | Hayward S220t Top Mount Pro Series Sand...
I recieved a Sp 0711-A13 Hayward Pro Series sand Filter and I have no idea how to hook it up. What are the requirements to attatch it to my above ground pool? There is no paper work.
you can go to http://www.haywardnet.com and get all the info you need. You can download a manual there. Go to products, and then above or inground and then on literature&manuals
Jul 23, 2010 | Hayward SAND FILTER, PRO SERIES
Recirculating a hayward sand filter for inground poola
no ... waste dumps the water ... recirculate recirculates but does not filter ... filter filters the water ...
Jul 15, 2010 | Hayward SAND FILTER, PRO SERIES
What to do about 14 psi ?
The actual pressure depends on how clean the sand is, how well the pump is pumping, how clean the skimmer and pump baskets are. The rule of thumb would be when the filter pressure raises 8-10 psi above whatever the pressure was when you first started the filter with clean sand, clean baskets, good pump, When it reaches the 8-10 psi, it's time to backfulsh. A low pressue, with adequate return flow is what you really want. See Hayward's web site for a manual. http://www.haywardnet.com/inground/products/manuals.cfm
Jul 06, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the sand in a hayward model 711 sand filtration system. Are there any instructions for this out there?
While there is a model 711 Hayward Valve assembly, the actual filter is a different model number. You might be able to find your model here...
http://www.haywardnet.com/inground/products/filters/sand.cfm
Apr 08, 2010 | Hayward SAND FILTER, PRO SERIES
When vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
240 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
