Question about Canon PowerShot S60 Digital Camera
One Powershot s60 flash does not work - all other functions ok -- lens assembly does make a bit of noise (sounds like gears) when extending compared to new or factory refurb unit Second Powershot s60 lcd screen will illuminate white but no image - otherwise all functions ok - will take pics and can extract pics from sd card - lens assembly makes same noise as above --
  • 1 more comment
  • armco Jul 14, 2009
    what about lens assembly noise? Impending failure?
    Will open back for a look at ribbon cable -- where is connector for lcd cable that would be culprit if loose?
    fixed lcd - ribbon connector tab popped up on lower right of front of camera - must have happened when I was blowing out the inside hoping to get trash if any out of lens assy --- thanks --
    lens assy barrel still makes (grinding?)/gear noise when opening and closing - compared to new/refurb unit I keep only for underwater work with waterproof case (also is s60) -- doesn't look like anything to be done but let it fail completely??? -- thanks again for the lcd fix - at least the thing is usable for now --
    yes - exceeded my expectations by a considerable margin and saved me at least 120 buckaroos :~))))
  • 2,200 Answers
Hi
On the first powershot you need to make sure the Auto Flash is not turned off (button top left on rear of camera) If it has been turned off a lightening strike symbol contained in a circle will show on screen and flash will not operate. You can cycle through AutoFlash - Flash On - Flash off by continually pressing this button.
If the flash does not respond to this command the flash unit is failing to charge and will have to be returned for service repair.
On the second powershot the LCD is white because it is not receiving a signal. This will be caused either by a disconnected ribbon inside the camera or failed circuitry. If you are brave you could open it and check for a poor connection to the screen but you may end up doing more harm than good!
Hope this helps to explain the issues you are having. Please remember to rate my answer. Many Thanks.
Posted on Jul 14, 2009
  • Radio Code Pro
    Radio Code Pro Jul 14, 2009
    Hi
    The noise from the lens assembly may well be an indication of impending failure but in my experience this can go on for quite a while before you get a total failure. Its impossible to predict with any certainty how long it will last.
    As regards checking for the loose connection - I would remind you this is not for the faint hearted as you will need to remove the lcd screen and backlight assembly to see where the ribbon connects. You will need to be meticulous throughout this process to ensure you do not break anything and take note of what you have done so as to be able reassemble in reverse.
    The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket.
    The ribbon cable that connects the LCD to the circuit board must be inserted correctly. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the “socket” deeply enough that the wider portion is pressed right up against the “socket.” It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket.
    There is a good video here which may help you. It shows swapping an Lcd on an A50 but the principle of disassembly is the same.
    Hope this helps. If so - please remember to accept and rate my answer. Thanks.
  • Radio Code Pro
    Hi
    Thats great. The white screen is a clasiic indicator for a loose connection. So you have a fully functioning camera at last! As I say in regard to the noisy lens mechanism its a wait and see approach. It could last like that for years or could just pack up all of a sudden. Short of sending it for service theres not a lot you can do with it.
    Oh and please ignore that crappy video - I posted the wrong darn link in and can't change it now!
    Glad to see it worked out for you - Don't forget to rate the answer!!
Lens error on the touchscreen
does the the motor sound stuck, does it not extend or retract properly? Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
May 19, 2010 | Nikon COOLPIX S60 Digital Camera
Lense won't extend. Has error screen that says "lense error, restart camera"
sounds drastic but turn on cam and grab hold of lens to try to fully extend it manually. if you hear a crunching noise that means the gears are stripped. not worth repairing
Jul 09, 2009 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error: camara has broken gears in lens assembly
Hi kevin3738 and a_nester
ok for kevin3738,
im thinking that since you said your lens doesn't extend all the way out that maybe you might have cracked a gear in the lens housing, the mechanism to extend that is located when you open the camera and take off the front face plate, on the right side of the lens housing **silver part** you see a black plastic casing attached to a motor on top and screws in it, that is what moves the lens housing in and out, in that are a few gears, i think 4 of them lat move the housing, 3 small ones and one big one that reaches down to the bottom of the housing, they are interchangable but im not sure as to where you could find a gear to replace the broken or cracked one,
And for a_nester
im gonna take a guess at what exactly the problem is on your camera, and it might be the lens autofocus
in that case you can look here
http://www.fixya.com/support/t780884-lens
or
http://www.fixya.com/support/t805636-cameras_lens_messed_up
Jul 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
My SD110 problem sounds similar...any ideas?
It sounds like the gear train that extends/retracts the lens is not meshing properly. This can happen due to dirt/debris getting in around the lens units and into the gearing, or damage to the gears due to impact (dropping the camera with the lens extended). You might try blowing some "canned air" around the lens while turning the camera on/off to see if you can dislodge the debris, but the unit probably needs repair to get it functioning correctly again. That model is about 4 years old, and for the price it was selling for in 2004, you can get a really nice new digital camera at today's prices.
May 06, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
E18 pops up
An E18 error refers to a problem with the lens. Generally you receive this error if the lens is stuck, which often happens if you drop your camera while the lens is extended or if something like sand or dirt gets inside the lens barrel/gears. Your situation, however, sounds different since the lens seems to extend before giving the E18 error.
If the lens is fully extending before giving the E18 error, you most likely have a problem with the lens sensor located around the O-ring inside your lens barrel... either the sensor itself is damaged or the little plastic piece on the O-Ring that triggers the sensor is broken. If that's the case, there is nothing you can do yourself unless you feel like taking apart the entire camera and finding a replacement piece.
If the lens only comes out a little bit and is not fully extending before giving the E18 error, it sounds like something is making your lens get stuck. If you've recently been to the beach or a park where there is sand, try using a can of compressed air and blow it into the little gaps in the lens barrel... you may be able to blow the sand/dirt out, solving your problem. If the air doesn't work and you feel comfortable taking apart your camera, you can get to the gearbox and manually retract the lens by following my instructions below. Otherwise, I'd suggest a repair shop.
WARNING: TAKING APART YOUR CAMERA VOIDS THE WARRANTY AND CAN BE DANGEROUS! The capacitor that charges the flash can still hold enough voltage to give you a massive shock even when the battery has been removed for some time. Please only attempt to disassemble the camera if you feel comfortable doing so. I accept no liability for anything that happens should you follow my instructions below.
In order to open the camera you will need to remove six screws on the outer casing (2 where the wriststrap ties on, 2 on the opposite side, and 2 on the bottom). After unscrewing all 6 screws, pull the back and front casings off from the bottom out, as there is a clip-hinge on the top next to the shutter button that needs to disengage before you can fully remove the casing. Once the casing is removed, there is one screw holding in the flash apparatus, on the side. Remove it and carefully bend back the metal cage around the flash apparatus and pull it up. The flash will still be attached to the camera with a pair of wires (yellow and black) and a ribbon cable... leave those in place. Please be CAREFUL when handling the flash because the capacitor (the big black thing under the flash) can hold enough voltage to give you a severe shock even with the battery removed. Underneath where the flash was you will see a multi-tiered black piece of plastic... this is the gearbox cover. Remove the three screws from the cover and carefully lift the cover off the gearbox. Inside will be a motor shaft and 4 gears (2 white, 2 black). Remove the BIG black gear closest to the lens. Then temporarily replace the gearbox cover. With the big black gear removed, the lens should freely glide in and out if you push or pull on it. Do this several times in order to clean out any gunk that may have gotten into the grooves of the lens barrel. Then, open up the gearbox, replace the black gear, and screw the gearbox cover back on. Replace the flash into the metal cage and screw it back in. Finally, put the metal outer casing back on the camera and, before screwing it in, try to turn it on. Hopefully it will work again and you can screw everything back in. If not, your problem will require significantly more disassembly.
Apr 02, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Camera stopped working, lense partially extended
Switch on - lens extends - screen comes up is the normal. Partial extension of lens and the rest does not follow. Why does the lens not complete its function? Probable cause dirt got into the slide mechanism is the simple answer. Very fine mechanism- would not try anything your self. Have you a service facility of watch repair shop near you. Or try the makers web site - they may offer a swap out facility for a modest fee.
May 17, 2007 | Canon PowerShot S60 Digital Camera
Canon PowerShot S60 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
