Question about Fisher and Paykel GWL11 Top Load Washer
Very slow to fill.
When I first turn it on, the water will spray normally, but after a couple of seconds it slows to a trickle. It takes at least an hour to do one load of wash! It does this no matter what temperature setting it's on.
    President:
  • 1,124 Answers
In the hose ends are screens.. Sometimes they get clogged.. Find the screens & either clean them or replace them..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
Top load washer, starts l flowing water normal and
Check if there is not a blockage in the supply pipe or the gauze filter at the connection at the back of the machine.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
Slow to fill the washer
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 10, 2010 | Crosley CAWC529JQ Top Load Washer
My washer seems is filling very slowly, and doesn't empty all the water out of the tub. I tried both temperature settings and it doesn't seem to matter. It will fluctuate back and forth on how fast it...
regarding your filling problem , most washers have small screen filters at the water intake, take your hot and cold hoses of of your machine and observe the fittings on the machine you will likely find the filters there they are just a mesh screen, remove them and clean , then reassemble this should solve your slow filling problem
May 08, 2010 | GE WPRB8050D Top Load Washer
Aprilair 550 water running but not trickling through filter
it hard to see make sure the filter is in the upright position i believe they mark it with a black strip. you want it so the little v's are catching the dropplets or water otherwise thats normal but make sure you change it every season.
Nov 21, 2009 | Humidifiers
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
152 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
