Question about Refrigerators
Door Adjustment - Is it possible?
I want to know if there is an adjustment to tighten the freezing unit door on my GE refrig. Is not mentioned in the owners manual.
  • 21 Answers
IF DOOR IS NOT SHUTTING WELL REPLACE BOTTOM HINGE AND CAM COMES AS KIT
Posted on Jul 15, 2009
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Refrig door not closing properly, needs a push,
DOOR IS NEEDING HINGE ADJUSTMENT. LOOSEN SCREWS IN HINGE, ADJUST DOOR TO ALIGN WITH SEALS AND TIGHTEN SCREWS TO RE-ADJUST.
Feb 20, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Apr 01, 2010 | liftmaster Chamberlain Garage Door Opener...
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Doors need adjustment
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Mar 14, 2009 | GE GSH25JFR Side by Side Refrigerator
I purchased a GE SS 22.5 CF Refrig. The doors do
usualy there isnt a height adjustment most common problem is worn door cam due to over weighting door the door cam is made from hard plastic and is known to wear out even break
Mar 01, 2009 | LG LRFD25850 Stainless Steel French Door...
REFRIGERATOR GSH25KGMCWW ICE DOOR WILL NOT CLOSE
hi Step 1: If the door won't shut tightly, tip the refrigerator slightly backward by propping up the front of the unit or unscrewing the front leveling legs two complete turns. Experiment with this adjustment until the door stays closed, but don't tip the unit very far out of front-to-back level.
Step 2: If leveling doesn't work, tighten the hinge screws. You may have to open the door (especially the freezer door) to turn these screws. On some units, you may have to remove a hinge cap or trim to reach the screws; pry off the cap or trim with a screwdriver. Sagging and looseness can be corrected by shimming the door hinges. Loosen the hinge and place a hinge-shaped cardboard shim between the hinge and the door. Then tighten the hinge again. Sagging may also be caused by a wrongly placed shim. In this case, you can correct the problem by removing the shim. Experiment with the shims; you may be able to eliminate the sagging.
Step 3: If the door is warped, tighten the screws that hold the inner door shell to the outer door shell. You may have to change or adjust the door gasket after making this adjustment.
Step 4: Check the catch. Newer units have a magnetic catch on the door. If the door doesn't latch properly, remove the magnetic strike from the inner door shell and shim it slightly with a piece of thin cardboard. You may have to adjust the gasket to conform with the new shim.
Oct 17, 2008 | GE Refrigerators
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Mar 25, 2008 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Refrigerators Logo
451 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
