Question about Refrigerators
During, wind storm, all electricty from utility pole, to house / pulled out.. power is back on, running but not freezing. or refrigeration, is there a reset button, or has compressor gone out?
  • 1,000 Answers
Depending on how old and the make and model of the refrigerator, it may have a control board that may be causing the problem.
Has the refrigerator been running at least 24 hours or more?
Let me know the brand and model number and I will research the problem for you.
Best Regards,
Posted on Jul 14, 2009
Why wont my transfer switch change back to utilities position when the power is restored?
It depends on the brand of switch and generator. A Generac has its brains in the generator control board, others in the switch, what brand of switch please?
Aug 20, 2014 | Electrical Supplies
LG Refrigerator not cooling
Call a technician because either a board was burnt out or the compressor or the start device for the compressor took an excessive load and is shot.
Sep 06, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Top Freezer has lost it's freezing power. It's set on the highest level 7 and doesn't freeze the food... also there is a clicking sound every 5 minutes or so... this has started since Wednesday since we...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Maytag Refrigerators
My power went out and since it was restored my fridge won't come.
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. Is there any sign of life on this control panel (IE do you see the stack of horizontal green bars lit up and does pushing the "freeze" or "fridge" button change them)? If not, then the most likely scenario is that you had a big power surge when the AC voltage came back and it blew out your control panel. If you can install an adequatley rated surge protector in the power line for your refrigerator you can prevent this from happening again.
Jul 08, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
My Frigidaire refrigerator took a huge power surge during snow storm. It burned out the relay and the defrost control. Replaced these parts but now the refrigerator is freezing on the top. Is there another...
Yes, there is a fan that distributes cold air throughout the freezer and to the refrigerator side. The fan is usually located behind an access plate near the bottom of the freezer side. You should be able to hear it if it's running. If you don't hear it, remove the access panel and look at it. If it's not turning, you will need to replace the fan motor.
Oct 16, 2009 | Frigidaire FRS26H5AS Side by Side...
Dryer won't start.
Check the dryer door switch and the thermal fuse.
Mar 15, 2009 | Maytag Dryers
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
