Question about Maytag CWE5800A Electric Double Oven
Maytag oven beeping the message is F5 oven needs to be turned off
Oven was put in December 2007
    President:
  • 744 Answers
Hello, the oven can be turned off from the breaker panel, the Error message F5 refers to your electronic oven control is bad. You can try to reset it by turning the breaker off for 20 minutes and reseting the breaker..if this fails to work you will need to replace the EOC. Hope this helps, if you have any further questions please feel free to comment again..Good Luck!!!
Posted on Jul 14, 2009
Oven shuts off with Error Code 4d21
This problem points to the controller card not functioning properly. It will need to be replaced. Here is a link so you can get the owner's manual:
http://www.manualslib.com/products/Jade-Range-Rjdo3003a-2904090.html
Check it out, it may help you figure it out.
Mar 19, 2014 | Jade RJDO3003A Stainless Steel Double Oven
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Dec 06, 2007 | Electrolux EOB6632 Electric Single Oven
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
I have a Kitchen Aid oven, model #KEBS107DWH2 and the hinges are "sprung" so the door will not close all the way to turn off the oven door sensor, unless you prop something up against the door. That said,...
You are very lucky if that machine lasted as long as it has. if you replaced those hinges in 2007 that's 10 years. The last one i bought they said we will be lucky if we get five to ten years out of the new one. Unless you want to put money in this one its probably cheaper to buy a new one in the long run.
They could not care less if you tell them you won't buy anything from them again. I had a large company official tell me that.
Apr 08, 2017 | KitchenAid Ovens
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Apr 17, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Oven beeping
See my solution to OVENMAN/April 12, 2007 which I posted on April 14, 2007. My solution to the F7 error message has been supplied to over 650 individuals with a high degree of successful application.
Apr 03, 2007 | GE JKS05 Electric Single Oven
Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Mar 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag CWE5800A Electric Double Oven Logo
895 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
