Question about Garden
185 cc lawnmower Briggs and Stratton was operated with mixed oil,
185 cc lawnmower Briggs and Stratton was operated with mixed oil and gas, though I think it may not have been the ideal condition (it may have only wanted gas?). It would not shut off at the end of mowing, and I released the kill bar several times hoping it would stop. I finally had to drive it into tall grass to shut it off. Now it will not start again even though I managed to remove most of the gas/oil mixture in question. What should I check (disconnected cable from kill switch?) or internal parts (and their locations) and change to help it run again?
    President:
  • 1,124 Answers
Was it blowing out blue-ish smoke before ??
Take the spark plug out and clean it good with gas & wire brush..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
WHAT CAUSES LAWNMOWER ENGINES TO SMOKW WHEN THEY ARE RUNNING FINE?
-Possibly mix little too much 2 Cycle oil to gas. If not it start burning oil.
Good luck
Mai
Jul 28, 2014 | Briggs & Stratton Garden
Do i put 2 stroke or 4 stroke in a 148cc engine
does the engine take oil? if it does then it is a 4 stroke and does not require mixed gas. if it doesn't have its own oil then it is a 2 stroke and requires mixed
Sep 25, 2013 | Briggs & Stratton Briggs Stratton...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
280H07-0166-E1 briggs engine blows smoke out exhaust
smell the oil if it smells like gas then the needle and seat in the carb is leaking if not remove the cylinder head and see if the gasket blew out and its sucking oil from the crankcase if not look at the bore for scores scratches and scraps
Aug 13, 2012 | Briggs & Stratton Briggs Stratton...
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
My Lawn mower seems to be produced by ALKO, but has the Briggs and Stratton emblem also. It is the 40b model and having just inherited it, I am trying to find out if I put just petrol in or whether I need...
Hi scottcoles5...
The easy way to find out if the motor is 2 or 4 cycle is to check to see if the engine has oil in the crankcase...if it does it is a 4 cycle and you will NOT have to mix oil with your gas. 2 cycle engines do NOT have an oil in the crancase and depend on the oil you mix with your gasoline.
You can also check the color of the gasoline in the tank, most 2 cycle oils contain a colorant to color the gas to let you know there is oil in the gas...
Free Answer...Please take time to rate me
May 31, 2011 | Briggs & Stratton Briggs Stratton...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
