Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony wega 55" six red flashes and will not power up?
  • 2 more comments
  • hdtvfreak Nov 17, 2007
    lcd
  • hdtvfreak Nov 18, 2007
    Thanks for your quick response. Great website!
  • poorsony Nov 24, 2007
    Our tv has the same problem. 6 red flashes and will not power up. Is there any more detailed directions on how to fix this yourself?
  • Anonymous Oct 31, 2008
    I have six red flashes and it will not power up.
  • 934 Answers
Hdtvfreak,
I think what you have there is a thermal fuse problem... Common in that model, Sony p/n# 1-910-023-93, and I can't remember if that gets you just a fuse or some sort of kit... Seems to me it has a connector and cable that was part of it..
The fuse though is a 102c 1a 250v and it's a bit of a tight squeeze installing it with removing the light engine.
Hope this helps!
Bill
Posted on Nov 17, 2007
Power light flashes green likes it turning on then flashes red 3 times. I just replaced lamp Sony Grand Wega KDF-55E2000
3 blinks should on this model mean "LAMP DOOR IS NOT CLOSED" BUT IT really means something else.
Can I assist you?
I can tell you how to prove this or not and if proved it is a simple and not expensive repair..
SD TECH
Nov 10, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv won't turn on anymore. The red light flashes 6 times then pauses for a couple seconds then starts flashing six times again. Just keeps doing it repeatedly
try unplugging the tv and waiting a minute and try it again if its still the same? It sounds like a Capicitor problem on the Power supply.
Dec 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't turn on...light flashes red 6 times
According to Sony's diagnostic chart, a six blink code means the plus/minus 17 volt line is not being supplied from the G1 board. (The Power Supply). I would replace the G1 board and that should fix your problem.
I hope this helps,
Skyassoc
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv red light is flashing six times. Any idea of what is the problem?
hi
seems that you have a bad low voltage regulation in power suply section
Oct 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power light flashes red
Check the Lamp Fan if it is OK then you need to replace Ballast Board it is what powers Lamp.
UED 1-800-648-6657 or Encompass 1-800-638-3328
May 02, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
