Question about Kenmore 659 Electric Dryer
I have a Kenmore Elite Oasis Dryer and it is giving me the code "L2" when drying on any cycle. It isn't heating either. I found no reference to this in the manual. Ideas?
  • 15,935 Answers
It appears your thermal fuse has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE questionIt appears your xxxxxxx has failed in this instance.
Posted on Sep 30, 2010
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Aug 19, 2009 | Kenmore Elite Oasis ST 7806 Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 659 Electric Dryer Logo
140 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
