Either locate the belt routing diagram that is usually located under the hood somewhere, or take a photo of the path of the current belt. Locate the belt tensioner pulley. Using an appropriate ratchet or belt removal tool, release tension on the old belt and slide the old belt off the pulleys. Thread the new belt over the pulleys in the same configuration as the diagram (or photo), release tension of the tensioner and slide the belt on it. Allow the tensioner to take up the belt slack. Inspect the belt for proper routing and to ensure that it is on all pulleys correctly.
SOURCE: need a diagram for serpentine belt 1998 Ford Contour 4cyl 2.0l.
98 ford contour 2.0 belt routing
here is a picture of routing and how to do it , etc. , good resource ..
J5
SOURCE: i need a diagram of 1999 ford contour serpentine belt
Top one is for a 2.0, with AC, bottom one is the 2.5 with AC.
SOURCE: need belt routing for a 1998 Ford Escort ZX2
Call a Ford parts dept and ask them if you can get a routing diagram they can fax or pick it up thats the best way label take weeks to get in so do that and keep the copy in your car file Please rate my response thank you very much
SOURCE: diagram for a 1998 ford contour serpentine belt
There should be one under the hood look good on the fenders also and front on top of radiator
SOURCE: need diagram for 1998 Ford Contour serpentine
1998
FORD CONTOUR - L4 2.0L 1989cc 121ci BI-FUEL FI N Z
Multiple Accessory, w/o A.C.
Multiple Accessory, w/A.C. (Mfg. After 2/98)
Multiple Accessory, w/A.C. (Mfg. Before 2/98)
More details, can find in DAYCO Catalogue
I hope helped with this. Good luck (remember rated thie help).
