Question about Sony VAIO VGN-SZ460N/C Notebook
Sony Vaio VGN-SZ460N - freezes on System Recovery
Computor: Stock Sony Vaio VGN-SZ460N
Symtoms: Freezes but not at the same place during Full System Recovery using the Recovery DVD Kit from Sony.
Background: This is a case of poor guy gets comp that needs cosmetic repair from rich guy.
The laptop had been dropped and the plastic frame work and hindge on the left side had broke- so she doesn't look pretty but with a little imagination and inginuty i fixed the left hidge to hold the screen monitor section correctly. The comp worked fine otherwise till his tech guy attempted a system recovery before turnign the comp over to me in order to delete all personal data via the system recovery onboard.
I ordered the REcovery DVD's from sony - which arrived yesterday.
I opted via the Vaio recovery console to delte all data via Erase and 0 write the full drive.
Did a RAM check via the Recovery console
Did a HDD write check via the Recovery Console.
Did a full hardware system check via the console.
All check - "Okay no errors found"
First attempt at full systm recovery with Vaio recovery section included on drive to factory specs. System froze after about 15 minutes into second re-boot of "Please wait while windows starts for the first time"
Second attempt - same exact thing.
Third attempt at full system Recovery with-out the Vaio System recovery on the HDD and reclaim hdd space which renamed a partion or added a partition of Drive "E" to the HDD: It made it further - it was adding Microsoft works trial and other software - up to 82% completion and froze - i just shut it down after let it sit for 6 hrs to see if it would go past that.
Running a HDD sector check now as i type. so far so good on the sector check over 50% complete.
What is causing the freeze on system recovery?
  • Buuunge
    Buuunge May 11, 2010
    Hello, It sounds like the system is overheating. Do you hear any fans running when you first turn the system on? Please make sure there is no cd or dvd in the drive when you do this as they also make a lot of noise. When you first power on the system it should kick on the fans until the BIOS takes over and slows them down until they get the sensor readings to start again. When components overheat they become erratic and do not always display the same symptoms either time wise or symptom wise.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
Posted on Aug 01, 2009
Driver fn hotkey recovery
install website sony vaio and fn keys function software install
Oct 18, 2013 | Sony VAIO VGN-SZ460N/C Notebook
Sony vaio vgn-ns140e computer freezes up
There are any number of reasons a computer would freeze, virus, bad ram, hard drive issues, device driver, and bad downloads. Try a system restore before this happened.
Apr 02, 2012 | Sony VAIO VGN-NS140E/S PC Notebook
My Sony VAIO VGN-NW350F keep freezing when im watching a video?!!
hi,can you help me? i have a problem of my sony vaio VGN-NW350F! MISSED base system device!
Jan 29, 2012 | Sony VAIO VGN-NW350F/S Notebook
I have a Sony Vaio VGN-SZ460N notebook i've upgraded the os from Vista to Windows 7, now i'm having problem with the BLUETOOTH and CAMERA driver. Could u plzzz help me to resolve the problem..... With...
The first step should be to browse the producers website to see if there are drivers for Windows 7. If not you can try to install vista drivers for your peripherals many times they work anyway.
Mar 13, 2011 | Sony VAIO VGN-SZ460N/C Notebook
I need drivers for ethernet controller, network controller, video controller plus Mass storage controller and PCI Devices drivers for windows XP of Vaio PCG-6G1M
Your Notebook Manufacturing Company SONY says that your Notebook Model VGN-SZ460N/C is optimized to work with Vista OS only. So the drivers you will be installing for XP may lost some of their functionality under XP platform. Still, you can download all your Notebook supporting drivers from this link.
Download Drivers from here
But remember to select your Operating System (XP/Vista/Seven) when you will be downloading from the above site.
I hope this will be helpful to you.
Dec 25, 2010 | Sony VAIO VGN-SZ460N/C Notebook
Vaio VGN-FZ340e freezes without reason!
Possibly you have a programme running in the background that is causing the freezes, could be a screensaver. i think at sometime microsoft will issue an update that will fix this problem.
Oct 15, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony vaio vgn-sz460n camera doesnt work
The camera driver/software might got corrupted or conflicts with other/ third party applications.
What you can do is to try reinstalling the camera drivers and software from the link below
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNSZ460NC
the camera drivers/software are listed under
Camera - 4 file(s)
Be sure to install everything under that category. Start from bottom to top.
Sep 22, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony Vaio VGN-SZ460N Freezes during Full Recovery
Probably a memory problem even though it doesn't show up on a memory test. Enter the bios and select the option for default setup, "not the optimized setup". Also if you have more then one memory module, remove one and try the install, if you have two try using the one you removed first as the only memory module during the install process. If you have any cards plugged into the computer, remove them all before starting the install. Also all usb cables. Make the system as simple as you can for the new install.
Jul 14, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony VAIO VGN-SZ460N/C Notebook Logo
1,096 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
