Question about Waterstone 4055-ORB Oil Rubbed Bronze Towson Deck Mounted Soap Dispenser 40
Pegasus Estates 861 360L towel ring installation?
I'm obviously not understanding these "easy" insturctions. I mounted the metal plate into the wall. Now the only think left to do is loosen a tiny set screw, place the toewl ring base on the metal plate, and tighten the set screw? This tiny screw doesn't hold up the whole thing. What have I missed?
  • lisa_wolkenf Jul 15, 2009
    yes, i see the groove on the top of the towel ring but the mount has no indentation for it to rest in.
  • 534 Answers
There is a groove on the top of rhe towel ring that the mount has an indentation that this groove sits in. The tiny screw pulls the groove into the mount in turn, holding the ring in place
Posted on Jul 15, 2009
  • david berry Jul 16, 2009
    the mounting bracket should be oval at both ends with a flat sides that (the sides) face up and down. The flat side of this bracket is where the groove sets and the bottom of the bracket, when you tighten the screw, it pulls down on the towel rack causing the groove to fall into the top flat section of the bracket. Good Luck
    I'm here if needed
    Dave
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
My hand towel ring is loose. The wall mount is secure but the ball that holds the towel ring and connects to the wall mount is loose and looks like it could fall off.
Usually there is a set screw in the side of the wall mount. If there is loosen that and take the towel ring down. There maybe a second nut or fastener you can tighten up the ball with. If not just buy another one. Some just get worn out over time its normal.
Feb 02, 2012 | Home
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
We just installed a Hoover central vacuum system. As soon as we plug it in the system starts even if the switch is off. If we disconnect the wire the system goes off. What did we do wrong?
You have either left the manual switch at the vac in the on position, or you have a low voltage short at one of your inlets in the house, or at the vac itself or where a pair of wires are connected together at a pipe junction.
Carefully go back inlet to inlet, remove the plates and be sure your mounting screw is not shorting two wires together. Trim any excess bare wire away and look for nicks in the insulation as well unless you see an obvious short. If you are using telephone type multi colored wire it is easy to bare an inside piece of wire while stripping the outer insulation.
Also be sure sure wires are paired the same color pattern at each inlet.
It is common to see a stripped wire touching another inside the wall or if you have metal backing plates in the wall a wire may be touching the plate and triggering the vac to turn on. Post back to advise,
the other possibility is you have a nail or screw in a wall piercing the wire but this is seldom ...
take your time,its an easy fix but it might be hard to spot
Oct 04, 2009 | Vacuums
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
Waterstone 4055-ORB Oil Rubbed Bronze Towson Deck Mounted Soap Dispenser 40 Logo
305 people viewed this question
Top Waterstone Home Experts
Donni Steen
Tom Chichester
Are you a Waterstone Home Expert? Answer questions, earn points and help others
