Setting says 70 while room temp says 75
Some thermostats might allow an adjustment, but you gave zero information on how you were measuring the temperature. Ask a poor question and get a poor answer. Next time give more information to get a better answer. It is Not being belligerent to ask you to give more information so you can get a better answer. Can't you see that short questions lack information that is needed to give a more specific answer? Example "I need help getting my cat, I can't reach it" Where is the cat? Is it in the house, or on the roof, or in a tree? Can you see that the question about the cat did not give enough details. Telling someone that your thermostat may need adjusting, but not saying what kind of thermostat it is, is not helpful. Maybe you don't know about how many different thermostats there are out in the world? Lighten up.
Testimonial: "I compared my thermostat room temp indicator to a regular thermometer which agreed. My thermostat setting was off from those readings. Why so belligerent With your answer?"
You're right, my apologies. Thermostat is a RUUD pn41-20804-16. Actual room temp reads 2-3
Deg hi or lo compared to setting depending if set to heat or cool.
