Question about Hayward SAND FILTER, PRO SERIES
My s[170-t model filter is not filtering. The water is going through the filter.
  • Anonymous May 11, 2010
    How old is the filter sand?
  • 990 Answers
Try removing the top on the backwash valve and see if the spider gasket is in good condition. If it has a problem it will appiear to have water going through the filter while it is actually by-passing in the valve.
Posted on Nov 05, 2009
Tecumseh XL 2338 E OH 160 170 170 G Manual
.030 is the plug gap. the air and fuel you can get at any mower parts store
Feb 17, 2017 | Tecumseh Garden
I have a Kithenaide refrigerator and the pressure keeps cutting out on the water dispenser I have replaced the dispenser moyorhe but this did not work I have also replaced the filter twice not sure what...
i WOULD CONSIDER CHECKING THE WATER INLET VALVE FOR OHMS AND FOR LIVE VOLTAGE
AS YOU MAY HAVE BAD COILS
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Mar 23, 2015 | Refrigerators
After changing the water filter, how do I get the red light on the control panel on the front of the refrigerator to go out?
WATER FILTER CHANGE REMINDER
For some refrigerator models featuring water filters, the Water Filter Change Reminder function monitors the life of the filter and provides a reminder when it is time for the filter to be changed. When the system detects either 12 months of usage, or the filtering of 416 gallons of water (whichever comes first), the change filter indicator light will illuminate. This
indicates that the water filter should be changed and the light reset. To reset Change Filter Light:
Press and hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 seconds). The control is now reset for 12 months or another 416 gallons.
A more complete manual can be found here=> http://appliance911seabreeze.com/index.html
In left sidebar and last item listed. Go to page 101, Thanks, Sea Breeze
Nov 21, 2010 | Maytag MZD2766GES Side by Side...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    No water to the ice maker
    filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
    Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
    DOES THE KENMORE ELITE FRIDGE REQ A WATER FILTER
    that depends if you want filtered water or not. if you like the taste of your tap water, then no. but if you have hard or well water, you'll want one to keep the pipes and solenoid clean.
    Nov 12, 2009 | Kenmore Refrigerators
    I need to bypass a filter in RS267LASH Samsung refrigerator
    From the Samsung Online FAQ for my RF266AASH
    Can I Use the Water Dispenser Without a Water Filter? spacer.gif The water and ice dispensers will work without an AquaPure water filter installed. The water filter housings are designed as rotary valves that allow the water to bypass the water filter whenever there is no filter or the filter is not in the lock position.
    Models designed for use with the AquaPure water filter are shipped with a cap in place to cover the opening and keep it free of debris prior to the installation of the water filter. It is not necessary to have this cap in place for the unit to bypass the water nor is it intended to plug the housing to prevent leaks.
    Note: This does not apply to the Quatro Convertible models. The filter must be installed on this model.
    Nov 21, 2008 | Refrigerators
    Kenmore elite washerabout 5yrs old model 170 ser# CK4512109. washer panel reading "Ld" washer came with house no manual
    Means long drain.
    Either pump is plugged, drain is clogged or filter is clogged.
    Please check filter, drain and than pump.
    Jun 03, 2008 | Kenmore Washing Machines
    Hayward SAND FILTER, PRO SERIES Logo
    126 people viewed this question
    Top Hayward Pool & Spa Experts
    Jay Finke
    Jay Finke
    Bill Jordan
    john h
    Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
