I have a client and when they send a Word job to their HP 4350 printer that's longer than 22 pages only the first 22 pages print. They're using PCL6 driver for HP 4350 and they're on a network. I resolved this issue a month ago by starting and restarting the print spooler. that did not resolve issue this time.
They only print these documents in Word. I'm not sure if more than 22 pages print in other apps.
Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
X PRINTER ERROR
A firmware error occurred
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
This error is usually caused by a bad formatter board
If the printer is processing jobs slow, especially for PDF's before they come out of the printer it's probably a printer memory issue. To test, send the print job at a lower resolution. If that works then you can just print jobs at that resolution or install more memory. If the print jobs are coming out of the printer slow then your printer settings may be set to the highest resolution of pro res instead of the default fast res which cuts the printer speed in about half.
he printing operation has been aborted. The
issue can be caused by a firmware error, invalid print commands,
corrupt data, invalid operations, poor quality parallel cables, poor
connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory. 2> Turn the printer off and then on to clear the error message. 3>
Try printing a job from a different software program. If the job
prints, go back to the first program and try printing a different file.
If the message appears only with a certain software program or print
job,.
