Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code
WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
- Press the [Machine Status] button on the Control Panel.
- Select the [Active Messages] tab.
- Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
- To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
- Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain
Description
303
Communications Error
305
Duplex Automatic Document Feeder (DADF)
310
Fusing
312, 313
Finisher
371 - 375
Paper Tray Feed
377
Sensor / Interlock Fault
391
Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
