Question about Alpine Air XL-15 Air Purifier
Alpine XL 15
Purfier simply stopped. I checked the fuse, it's ok. what do you advise.
  • mariecha Jan 17, 2008
    i have alpine air xl- 15 air purifier and it just stopped last night. i checked the fuse and cleaned the filter and still it wont work, but there is power in it but the fan doesnt move. thanks
  • 368 Answers
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Posted on Nov 11, 2011
The fuse for Model #XL-15 is 240 volts, 1 amp approximately 1 1/8" long.
Several sites offer them for sale, one such site is at Alpine air products:
Posted on May 24, 2008
Sorry I can't answer you but I would like to know what size is the fuse. I bought the same air purifier and the fuse is missing. Please e-mail me at Thanks
Posted on May 05, 2008
The fan motor shaft gets dirty remove the motor and disassemble ( really easy when you look at it) clean with rubbing alcohol then lube with sewing machine oil
Posted on Jan 19, 2008
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
My XL-15 won't power up. Everything seems to be in place but when I flip the power switch to the on position, nothing happens. I have looked at the fuse and it looks ok. Could there be another...
Hi Jan,
If the fuse is good and you are sure your outlet has power, then check the safety switch is being depressed. On the back is the lint screen, there should be a clip that depresses the switch. Hope this helps you.
Jun 30, 2011 | Alpine Air XL-15 Air Purifier
Got no power on my alpine xl15, someone told me the rectifier seems to fried and to change it, does anyone know where I might order this part? Thank You, Nemo Kim
Please check the fuse first. Unscrew or unlatch the small knob at the back of the machine and inspect the fuse. Even if it looks OK, you probably should replace it. Be sure to get one that is the EXACT same size, available at an auto parts store. If the fuse was the problem, the new fuse should allow your machine to power up and work well.
Make sure the plates are inserted firmly and correctly into the grooves at the top and bottom, so the fingers press firmly on the screen portion.
If the fan now works, but you aren't detecting any purifier (or hearing the buzz caused by the electricity cycling through the plates) you'll need a new transformer. This sends the power through the contact fingers to the plates. Vollara (formerly Alpine/EcoQuest) no longer makes the XL15. The newer machine is called the Classic. Call customer service and they'll tell you what your options are. 800-989-2299. Use #16618 if you need a referral number.
Jan 11, 2011 | Alpine Air XL-15 Air Purifier
Alpine air filter X15 not coming on, what could be wrong
I would check the line fuse located near the power cord. The other thing would be the safety switch. Make sure the clip on the lint filter is making contact witht the safety switch.
Dec 07, 2010 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
I need Alpine Air XL-15 Air Purifier Repair service
Best bet is to call EcoQuest at 1-800-989-2299 and they can direct you to the closest repair center.
There is also a way to upgrade to a newer model the FreshAir 2.1 getting $100 back for your old XL-15.
To do this go to or call 1-800-798-6925 and ask for Eric.
Jan 13, 2009 | Alpine Air XL-15 Air Purifier
No lights no fan on Alpine Air XL-15
Use a DVM continuity function to see if the fuse is blown, and check all the DO FIRST literature packed with the thing. You probably get to take a note out of the ionizer chamber.
May 13, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15 not working after cleaning
Bottom small plastic covered screw is a trigger for interlock switch, won't work if it doesn't push in the metal trigger.
Jan 14, 2008 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
349 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
