Question about Cell Phones
I do not know how to use it
I do not know how to use the data cord
    President:
  • 1,952 Answers
It has to have gprs and it must be modem enabled
3.You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or usb cable)
4.You need a dialup connection
5.You need to know and change your proxey settings
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either buletooth,infered or a usb cable, date card
Step 2:Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dialup connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your cpanel there should be something called modem options (If your 's doesn't have you'll have to search your computer for an option that allows you to change the acess point name or also known as the APN) here you must change the APN to whatever your APN is on yor gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet exploxer,opera etc) and start surfing the net.
Note that every cell phone has it's own speed for example 3g phones can reach up to speed's of 48 kb/s.
I've tried to make this tutorial as simple and as easy to follow as possible.
Posted on Jul 14, 2009
  • 27 Answers
Cell phone? what kind of cell phone? plug it into the port on the phone then plug it into the usb on the computer, might need to have a program though in order to transfer things to ur phone or vice versa....good luck
How to access the application data and port all my plain text notes out of it?
Depending on the application, you may be able to use iTunes to collect application data if it is supported by the app.
  1. Open iTunes on your computer
  2. Connect your device (iPhone or iPad) to the computer via apple cord (Do not use a non-apple branded cord)
  3. Once the device is detected click on it at the top
  4. Click on the tab for Applications
  5. Scroll down and you will see the app data section, if your application supports export of the data you will see it there.
If you don't see it, if possible do a copy/paste of the text into an email. These to the best of my knowledge these are your only two options without knowing specifically what application you are working with.
Oct 06, 2015 | Apple iPad Tablets & eReaders
My WD hard drive shows up on windows explorer but when I click on the icon it states that I need to format the drive in order to read it. I have loads of precious data on this hard drive. How can I...
I had the same problems with mine. It got to the point that the drive wouldn't even spin up all the time. I got lucky one day, and it did spin up & I was able to get my data off the drive. Counting this unit, it is my fourth WD HDD failure! Needless to say, there are no more WD drives in my house!! Are you plugged into a "native" USB port? Try that if you are using a hub. Also try unplugging the USB cord into the unit and plugging it back in again alternating with turning it on and off using the big button on the front. It isn't just a HDD in a case. There is a weird electronics board inside that connects and controls the drive. NOT a regular IDE or SATA connection, so you can't just take it out and hook it up using an IDE to USB and power supply to get your data off. Do other USB accessories run OK on your USB ports? Sometimes THEY get strange and won't work or won't work correctly. Disconnect the "My Book" USB cord, shut your computer off, pull the power cord completely out of your computer, press the start button on your computer for 5 seconds. Put the power cord back in, start your computer and reconnect the USB to the My Book. Doing the above will usually fix the USB ports that have gotten corrupted for whatever the reason. You might also try running it on another computer and see if you get the same results. Hope any of this will help. Let me know if it does, and please rate me accordingly. Good luck....I know all too well what it is like to loose data.
Jan 08, 2010 | Western Digital My Book Essential Edition...
I want to transfer my data to computer. with out using usb cord...how i can do i dont have bluetooth and infared...
if you dont want to use any USB cord, try using the web on your CP if you know how. if not, invent a device to connect your mobile on your PC, install it on your PC.
Nov 06, 2009 | Nokia 1680 Phone Unlocked FREE 1GB
Broken usb connection
The best thing to do is just take it to the technician,or the place you purchased it from. Do not try to fix it your self cos out of curiosity it would damage it further, unless you are a technician ofcourse. The problem you mentioned just needs a replacement of the USB slot which can be done by the technicians easily.
Jun 29, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
My rim blackberry is switching off frequently and shows Device error:373 pls tell how to solve this problem
Try taking the battery out for about 10 minutes. Plug in the power cord only. Once it powers up with the power cord only then put in your battery. Unplug the power cord only after the battery is showing a full charge. Turn off the device and turn it back on.
If that doesn't work you can try dropping it on the ground a few times on a carpeted area. Make sure it drops on the face about 5 or 6 feet up. I know...I know...sounds crazy.
Otherwise, you can wipe it clean but that erases all data on it.
Apr 24, 2009 | RIM BlackBerry 7290
Polaroid a300
I think you're looking for something like this:
http://cgi.ebay.com/USB-2-0-A-Mini-B-5-Pin-PC-Digital-Camera-MP3-Data-Cable_W0QQitemZ110265688402QQihZ001QQcategoryZ42322QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or
http://cgi.ebay.com/6-Feet-USB-2-0-A-to-4-Pin-Mini-B-Data-Cable_W0QQitemZ350074273471QQihZ022QQcategoryZ42322QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They're both the same kind of cord..just wanted to give you a selection. I have the A300 as well so I know what the cord looks like.
You can get it on Ebay or go to a computer store(or a Wal-Mart) and buy it...make sure to look for "Mini USB"(the small end of the cord)..and make sure the other end looks like a regular USB(USB 2.0).
Jun 04, 2008 | Polaroid a300 Digital Camera
How can i open the case to see what the problem is
I think, it's bad backlight. you need to replace the backlight or the lcd.
Dec 23, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Cell Phones Logo
193 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
