BUZZER CONTINUES TO SOUNDWHILE DRYING
Www.ehow.com > Home > Home Appliances > Washer & Dryers
YOU MAY HAVE TO REPLACE THE BUZZER. FOLLOE THE SIMPLE STEPS AND , WHO KNOWS YOU MIGHT MISS THE BUZZUNG SFTER YOU FIX IT.
SOURCE: Amana gas dryer buzzes and won't start
Jeff, what you are describing is a drive motor that is locked up. The only cure for this is to replace the motor. This is probably the most difficult repair to perform on a dryer. You will need to have a lot of patience if you choose to proceed.
I looked up the motor for you, it's a part number 511629P and it lists for ~$145.00. That's alot of clams for a motor! And I presume this unit has some years on it, right? Which means that if you replace the motor, there's a good chance that another component will fail soon.
I'm not trying to dissuade you from a repair, I'm just mentioning possible options. But, if you want an opinion on this, mine would be to replace the dryer. I know this isn't what you wanted to hear, but I hope it helps you decide what to do.
If you choose to repair, write back and I'll do my best to walk you through the procedure.
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
SOURCE: Have AMANA dryer ALE230RAW. Hear buzz when start
I also have this problem, but it is after the dryer has been running. When the motor is hot, it buzzes and will not run. Sometimes it will run if I turn the drum or take some clothes out. I disassembled the dryer and cleaned the motor of lint. This helped but not completely solved the issue. I have completely removed the motor and will thoroughly clean the motor (stator and brushes) and will try again.
SOURCE: amana dryer mod. ned5100tq1 will not start. It only buzzes when i push the start button
Does it buzz or growl? Reach inside and turn the dryer by hand. Is the drum hard to turn? Might be a bad roller or possibly something stuck in the filter chute and lodged against the blower. I worked on a dryer exactly like yours and made a video. If the blower is clean and clear of obstacles and the wheels are fine then the motor needs to be replaced which is easy to do. The hardest part is getting the blower wheel off the motor (backward threads on it) Motor replacement video:
Manual and more is on my BLOG PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
