Question about Boating
I need a manual for a Zercom LPG2000 fishfinder. Could you tell me their homepage address? yonglee@yonsei.ac.kr
How many volt , ac.or dc. for power supply phonic MM1202 mixer
I tells the power supply model numbers on the back of the unit above the power connector plug. It doesn't tell the specs as of how many amps but does describe several voltages of AC it would work on and also gives several model numbers of the correct power units that are sufficient. If you don't use one the recommended units, it could malfunction and give extra static noises caused by improper filtering of the power. It shows on page 8 of this manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=39&ved=0CHkQFjAIOB4&url=http%3A%2F%2Fsoundhouse.co.kr%2Fsoundh%2Fcatalog%2FPHONIC%2Fmixer%2FM-U-1-2-0-2_1-2-0-2-X_om.pdf&ei=QPdbUaX3K4zA9gS11IFY&usg=AFQjCNGoMutp27pESma_-Mw36637hlmHOA&sig2=8J0-4rb6sHlit-OdKlIFbg
I hope this helps you.
Mar 31, 2013 | Phonic Music
Tip
Gprs & MMs settings for england cellphone networks
&gt;T-MOBILE GPRS SETTING <br /> <span> </span>#Account Name - T-MOBILE GPRS <br /> <span> </span>#Username : user <br /> <span> </span>#Password: wap <br /> <span> </span>#Homepage: http://wap.t-mobile.co.uk/ <br /> <span> </span>#GPRS APN address: general.t-mobile.uk <br /> <span> </span>#Gateway (IP) address :149.254.001.010 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Port number: 9201 <br /> <span> </span>#Authentication: Normal <br /> <span> </span>&gt;T-MOBILE MMS SETTING <br /> <span> </span>#AccountName:- T-Mobile <br /> <span> </span>#Data Bearer:- GPRS #User name:- mms <br /> <span> </span>#Password - T-mobile tell you this when you register <br /> <span> </span>#APN:- general.t-mobile.uk <br /> <span> </span>#IP address:- 149.254.211.10 <br /> <span> </span>#MMS Server:- http://mmsc.t-mobile.co.uk/ <br /> <span> </span>&gt;ORANGE GPRS SETTING <br /> <span> </span>#Account Name :- ORANGE GPRS <br /> <span> </span>#Homepage: http://orange.multimedia/ <br /> <span> </span>#APN address: orangewap <br /> <span> </span>#Gateway (IP) address : 192.168.071.035 <br /> <span> </span>#Username : Multimedia <br /> <span> </span>#Password: Orange <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: NormaL <br /> <span> </span>&gt;ORANGE MMS SETTING <br /> <span> </span>#AccountName:- Orange <br /> <span> </span>#Data Bearer:- GPRS <br /> <span> </span>#APN:- orangemms <br /> <span> </span>#User ID:- Orange <br /> <span> </span>#Password:- Multimedia <br /> <span> </span>#IP Address:- 192.168.224.10 <br /> <span> </span>#MMS Message Server:- http://mms.orange.co.uk/ <br /> <span> </span>&gt;VODAFONE GPRS & MMS SETTING <br /> <span> </span>#Account Name - VODAFONE GPRS <br /> <span> </span>#Homepage: http://wap:1999/vodafone.wml <br /> <span> </span>#APN address: wap.vodafone.co.uk <br /> <span> </span>#IP address: 212.183.137.12 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: Normal <br /> <span> </span>#Security: Off <br />
on Jan 11, 2011 | Cell Phones
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
Mamual
hello there:
here is a few links that have the manual that you can download for free
  1. Humminbird 595C Manuals, Support and Troubleshooting - Fishfinder GPS Free download of Humminbird Fishfinder 595C User Manual. ... Humminbird Fishfinder 595C GPS. Need a manual? HUMMINBIRD 595C MANUAL ...www.retrevo.com/support/Humminbird-595C-GPS-manual/id/540ag515/t/2 - 96k - Cached
  2. Humminbird GPS Manual and Support Information: User Manuals: Retrevo ... largest collection of user guides and manuals on the web. ... Humminbird Fishfinder 595C. Operations Manual. Humminbird HDR 400G. User Guide. Humminbird HDR 400I ...www.retrevo.com/samples/Humminbird-GPS-manuals.html - Cached
Sep 16, 2009 | Humminbird 595c GPS Receiver
Station memory problem
Sorry, I haven't addressed the station memory problem further since replacing the AC switch by-pass capacitor, which same didn't solve the problem. I'm using the receiver only as an amplifier for a Roku SoundBridge, so the station memory isn't a problem at present. When we return to AZ, I may look at it again.
Sep 04, 2008 | Kenwood KR-A3080 Receiver
Boating Logo
206 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
