Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Ge triton I got my GE triton about 2 years ago and it has worked fine since. For some reason, now, it won't stop running through the wash cycle. I can't get it to turn off. I push the reset button hoping it will stop and all it does is go to "sensing" then back to wash. I have to open it to get it to stop temporarily, but there is water sitting at the bottom of it. Any suggetions?
  • fallon431 Jun 12, 2008
    triton dishwasher won't turn off, just keeps washing and washing, and sensing and washing
  • timmsli Sep 17, 2008
    I have the same problem, but flipping the breaker did not help.
Turned the breaker off and then on again..... Works like a charm!!! Thanks
Posted on Jan 28, 2009
It works by turning off the breaker!!
Posted on Dec 04, 2007
Power outage was the culprit for me as well. Resetting the breaker fixed it immediately. YAY!!
Posted on Nov 20, 2007
Motor groaning on GE Triton XL Dishwsher
motor coils partly burned turns different direction in spin
Aug 08, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My washer will not spin.
hi..the reason to this problem is probably due to the
lid switch.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | GE WBSR3140DW Top Load Washer
GE Triton not working
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Middle arm stopped spinning
you may be exactly right. I always start with something simple. spin the spray arm to make sure it goes all the way around with out touching anything. next is the hard partyou would have to take the motor apart and any filters you see and clean out all the debris.
Nov 27, 2008 | Dishwashers
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl dishwasher
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Nov 17, 2007 | GE WHRE5260E Top Load Washer
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Triton Dishwasher won't stop running
try to reset the circuit braker--remove all power.
Aug 27, 2007 | Dishwashers
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
1,219 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
