Question about Dryers
Dryer stopped running after 10 minutes
Just put a load of towels in the Kemoore 80 series dryer and it stop running and wont start up again. Light still works
  • seankjanson Jul 15, 2009
    We let the dryer cool down I guess and it worked after about an hour. I guess the load my wife put in was still too wet and heavy.
    Thx fot the help.
  • 52 Answers
Take off the back, there will be a oblong fuse, it has two little wires, replace it.
Posted on Jul 15, 2009
Dryer stops after about 10 minutes. can be re-started but stops again and again. Thermostat was replaced about two months ago.
the motor could be overheating,you might need a clean out on the dryer?vac out the inside where the motor is,clean out the duct where the lint filter slides into and then go outside and make sure the air is blowing out with force,i've been finding alot of cages outside that stop animals from crawling into the vent line but the cage also catches lint and stops the air flow,if so take the cage off or clean it every month,if you have a long run blow out the vent line with a leaf blower,you could also have a bad motor
Jan 19, 2010 | Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Dryer stops running after 5 minutes
you may have a defective door switch.
Oct 27, 2017 | Dryers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Dryer stops after a few minutes of a full load.
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
