Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I need to install the switch lid - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • 5,911 Answers
The following link explains how to install a lid switch on a Whirlpool model top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have any questions about this repair, or if your lid switch is located somewhere other than what I have described, please let me know. I hope this helps you.
Posted on Jul 14, 2009
My Kenmore Washer model: 110.49962603 stops during the rinse cylce. All the buttons were turned off after one cycle except the time button. It displays F28 on Time Estimated Remaining button. How can I fix...
By what you have stated, it sounds like a lid switch failure. The lid switch has to be closed for the drain and spin cycle on your washer. If the lid switch is faulty, it will act as if the lid is not closed. On this model, make sure the lid hinge screws are tight. If the screws are loose, the hinge might not activate the lid switch.
A quick check you can do is to jump the lid switch and see if it will drain. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console. I have provided you with the instructions for opening the console below. Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and tan wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Start the washer in a drain cycle. If the washer drains and spins, you need to replace the lid switch. Do not leave the jumper in while you are waiting for the part. The jumper is only of the test.
To you replace the lid switch you have to remove the cabinet of the washer. The instructions for that are also in the image below. Once the cabinet is removed you can take the screws out securing the lid switch and remove the harness from the clips along the underside of the cabinet. Then reinstall the lid switch in the reverse order. Before you reassemble the cabinet, please read the instructions for installing the cabinet provided in the image.
I hope this is helpful. Please reply below if you need further assistance.
Jan 23, 2018 | Kenmore HE2 Plus Front Load Washer
Sun roof won't open, but i hear the motor turning
Check for any obstruction in the rail.
Also, can check this procedure to test your components...
Power Sunroof - REMOVAL & INSTALLATION (click over pic for zoom)
Motor
See Figure 1
  1. Remove the sunroof switch panel by pushing it to the side and disengaging the pawl, then pulling it downward.
Fig. 1: The sunroof switch panel is retained by a metal clip
  1. Remove the sunroof switch bracket.
  2. Unplug the sunroof motor wiring harness connectors.
  3. Remove the sunroof motor mounting screws.
Disassembly of the sunroof motor is not recommended.
To install:
  1. Lightly lubricate the drive gear with grease and install the sunroof motor to the sunroof assembly.
  2. Plug in the electrical harness connectors to the sunroof motor.
  3. Operate the sunroof to verify proper operation.
  4. Install the sunroof switch bracket and the sunroof switch panel.
Sunroof
See Figures 2 and 3
Fig. 2: Exploded view of the sunroof assembly on 1993-94 vehicles
Fig. 3: Exploded view of the sunroof assembly on 1995-97 vehicles-1998 models similar
  1. Tilt up the sunroof lid.
  2. Remove the lid side trim.
  3. Remove the lid bolts and the lid assembly.
  4. Remove the rear drain mount screws and the drain.
  5. Remove the shade assembly holders from the sunroof frame.
  6. Remove the shade assembly.
  7. Remove the sunroof switch, interior accessories and headliner.
  8. Remove the switch bracket.
  9. Remove the motor assembly, spacer and clip.
  10. Remove the wind deflector mount holders from the sunroof frame.
  11. Remove the wind deflector.
  12. Disconnect the drain hose.
  13. Remove the sunroof brackets.
  14. Remove the sunroof frame assembly.
  15. Remove the link and wire assemblies.
To install:
  2. Install the link and wire assemblies.
  3. Install the sunroof frame assembly.
  4. Install the sunroof brackets.
  5. Connect the drain hose.
  6. Install the wind deflector.
  7. Install the wind deflector mount holders on the sunroof frame.
  8. Install the motor assembly, spacer and clip.
  9. Install the switch bracket.
  10. Install the sunroof switch, interior accessories and headliner.
  11. Install the shade assembly.
  12. Install the shade assembly holders on the sunroof frame.
  13. Install the rear drain mount screws and the drain.
  14. Install the lid bolts and the lid assembly.
  15. Install the lid side trim.
Hope helps (remember rated this help).
Jun 03, 2010 | 1996 Nissan Maxima
-Washer Lid Switch 3949247 (3949237) for WhirlpooI received and installed a washer lid switch. Washer runs fine, only thing is when the lid is opened the washer does not stop. Lid switch is suppose to stop...
why did you change sw/ did washer not spin ? or same problem . you may have a shorted of faulty ( new ) sw . just because its new doesn't make it good / ck with ohm meter .. if the problem is same as before sw installed the we need to lok at a different problem . like ( timer ) or wiriing . ) mm give me some feed back and wi can go / and model # brand .. . help is on it way .. mm
Dec 12, 2009 | Washing Machines
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer gets to spin cycle and stops. It appears
Hi, if this is a whirlpool model machine, you can't just remove the top. The whole cabinet needs to be removed. You can change the lid switch without removing the cabinet. Remove the two screws holding the lid switch. Pull the lid switch toward the middle of the opening and snip the wires. You can splice the new switch onto the old wires using wires nut connectors if you want. If you want to use the whole wire harnes that comes with new switch, remove the two screws that hold the control panel to the cabinet. now yuou can see the lid switch connection (easy plug in) located in the middle. Unplug the lid switch and force the connection downward. Remove the old switch and install the new.
I can get you part# or send you the part off my web site www.whirlpoolpartssurplus.com if you would like. I would need the model#
I hope this helps.
THanks
Vic
May 15, 2009 | Washing Machines
How to install lid switch
The symptom of a washer that fills normally, but stops suddenly and will not drain is commonly caused by a lid switch malfunction.
The following link explains how to install a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If this is just a matter of reinstalling a switch that has come loose, a new switch may not be required. Inspect to ensure the mounting screws, switch casing, or switch lever are not broken. Make sure the mounting screws are tight. NOTE: You do not have to drain the washer to replace the lid switch. With the switch replaced, the washer will drain on its own. This will save anyone the trouble of having to bail. If you have questions, please let me know. I hope this helps.
Apr 25, 2009 | Kenmore 24032\24036 Top Load Washer
How to install lid switch?
Its an EASY fix , I can help , there should be 2 phillips screws on top of unit under lid holding the lid switch in place , unplug the unit and remove screws , the switch is now loose you should be able to grab it with your hand and pull it out to where you can see it , I recommend cutting the 2 wires going to it and using wire nuts to reconnect them to the new switch to make things easier. if you have any more probs. or questions please let me know.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Aug 29, 2008 | Washing Machines
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer will not run pump
Check your lid switch. This is a tell tale symptom of a lid switch gone bad. The washer fills, agitates, but will not spin or drain. The lid switch is located along the right hand side of the lid opening on most models, but some newer models have a switch in the left rear of the lid. Simply open and shut the lid several times and listen for a distinctive "click" of the lid switch as you open and close the lid. A lid switch usually runs about $35 to replace. If you provide me with your washer model number (usually located under the lid somewhere) I can give you the part number you need. That is...if the lid switch is the problem. The only other problem that I have encountered that caused the same symptoms, was a bad timer. Timer vs Lid Switch: Lid switch is a cheaper fix. I would try this option first. Let me know if this helps and/or if you need more guidance.
Sep 21, 2007 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal De
